d21 gearbox rebuild no2
Posted: Thu Jul 21, 2011 10:31 pm
by will i am
like any young farther on a apprentice wage i was on the hunt for cheap parts
looking threw trade me i found a cheap gearbox for one off my diesel terranos
bought it. put it in and bearing noise in the higher gears, drained the oil and out poped a piece of metal
at first i thought it was part off a bearing.
after half the day off thinking what it could be i figured id seen it from 3/4 syncromesh/gear unit
long story short i now have two terranos with gearboxes that need rebuilding again
i will post some pics and info over time on how i get along with the rebuilds
also if anyone has a diagram off the terrano gearboxes (manual) that would be very helpful and even a transfer case diagram.
im going off a ca18 diagram which is mostly the same
Re: d21 gearbox rebuild no2
Posted: Thu Jul 21, 2011 10:40 pm
by sibainmud
Bloody 'rano boxes.
I'm going to have to work off those ca18 diagrams too.
Now, I (like you), have 2 terranos, 3 gearboxes with 2 of them being rooted
Watching to see if some drawings come up.
Posted: Thu Jul 21, 2011 10:46 pm
by will i am
sibainmud wrote:Bloody 'rano boxes.
lol
yea i have 3 gearboxes.
should be able to make 2 good gearboxes if i buy 1 bearing set
also if anyone knows were to get genuine bearings at a good price i could be keen
Posted: Thu Jul 21, 2011 10:49 pm
by sibainmud
Go for needle roller bearings, or different gearbox all together.
Posted: Thu Jul 21, 2011 10:51 pm
by Sketchy_Racer
You will probably find it is a chunk that has broken off the counter shaft after the key way have been ripped to shit by the backlash.
I've done this to my box twice now, i've had enough so I welded it on this time. Not exactly "precision engineering" but will be stronger than the two keys from stock albeit non serviceable.
Also check to make sure your spigot bush is in good nick (one in the flywheel) as if that is buggered it will put nasty forces on the front bearing and needle roller bearing between the main shaft.
Posted: Thu Jul 21, 2011 10:56 pm
by Swamped
I'd be checking stuff over pretty closely if metal came out with the oil.
Maybe terranos are ok but in my mind if you only replace some bearings and one of the old ones you left in lunches itself your gonna kick yourself. I've done it once, never again. IF bearings aren't too pricey I'd do the whole lot while its apart.
Posted: Thu Jul 21, 2011 10:57 pm
by sibainmud
This is the closest I have, (robbed it off trade me)
Posted: Thu Jul 21, 2011 11:01 pm
by will i am
defiantly going to replace all bearings
http://www.trademe.co.nz/Browse/Listing ... =392808838best and only price i have found.
Posted: Thu Jul 21, 2011 11:08 pm
by Swamped
I'd get the gasket from nissan as I'm too lazy to cut something like that out but can't you just buy the bearings individually? I put all skf bearings in a car box I had and it was way cheaper than a 'kit'. Just needed the old ones to measure off of.
Sometimes factory stuff is better than aftermarket but just an idea.
Posted: Fri Jul 22, 2011 6:44 am
by u13turbo
Looking forward to seeing the rebuild photos, I'll be rebuilding mine in the next month or 2. Were do you source needle roller bearings?
Posted: Fri Jul 22, 2011 8:49 am
by Swamped
I just got em from skf. so saeco or up here they are waikato bearings.
Posted: Sat Jul 23, 2011 10:05 am
by meatc
what ever you do dont put the standard bearing back in it. Take the bearing to a bearing shop and get the needle roller equivalants.
My old box was done once by a "reputable" company on Pamure Auckland, they did half the bearings with standard ones and left the rest, box shat itself less than 18mths later. Had a semi retired gearbox guru rebuild it second time around and he did it with roller bearings and it was a better box than it had ever been.
Guy that did it said he had seen plenty of terrano boxes fail under 100K on stnadard bearing, then fail agin within 100k if done with standard bearings.
I put 180k on mine after the second rebuild and it was still smooth, quiet and easy shifting, and it is still running around 4 years on from when I sold it, must be gettin on for 1/2 million ks on truck and 300 on box since last rebuild.
Posted: Sat Jul 23, 2011 7:33 pm
by will i am
found needle rollerbearings on the saeco website
http://www.saeco.co.nz/needleroller.htmhave to ring up on monday and get a P&A
if anyone else is keen on some will try and get them to do a bulk deal.
let me know
Posted: Wed Jul 27, 2011 6:40 pm
by will i am
emailed a few bearing and gearbox companies and they say you cant use needle roller bearings
"You can use cylinfdrical roller bearings, but then
you have no location on your shafts and end up with 5th gear problems" and that's one email i have had back
best bearing kit price so far $185 being a TM series bearing. meant to be a heavy duty bearing. will still need to buy lock nuts on top off that and front gasket and seals
onto another part off a story
bought a fully rebuilt gearbox from one off the garages down here who rebuilds a few off these, the guy said to use 2l 80w90 and 2l normal mineral engine oil 15w40.
said not many people know about doing this and it helps keep the gears and especially the syncro units clean and better shifting
has anyone tried this before?
Posted: Wed Jul 27, 2011 7:31 pm
by u13turbo
I could be keen on a group buy for the bearings
Posted: Thu Jul 28, 2011 4:00 pm
by will i am
boss said i couldnt use the work shop during work hours
so.....
got to the workshop at 4:40am this morning
. draged my personal terrano on there and put this fully rebuilt gearbox in there. all in except for startermotor and battery by 7am. put 2L of 80w90 and 2L of 15w40 in the gearbox part and 2L of 80w90 in the transfercase.
need to bleed the clutch. or even replace slave and master if i can get them cheap threw work.
took it for a test drive after i put a ball joint and fucked around getting other stuff done on her.
drives real nice (gearbox)
probably the best d21 manual ive driven so far. (probably cause most off the other ones ive driven have had issues)
still have to take the gearbox out off the other truck now tho
Posted: Thu Jul 28, 2011 8:52 pm
by slide
Just looking on trademe and found this listing. Someones asked questions about terrano gearbox bearings and use of needle rollers.
http://www.trademe.co.nz/motors/car-par ... 806635.htmI'm also needing to rebuild my gearbox soon. Will be removing and stripping this weekend.
Be interesting to find cost of bearings individual vs kit
Posted: Thu Jul 28, 2011 10:45 pm
by will i am
slide wrote:Just looking on trademe and found this listing. Someones asked questions about terrano gearbox bearings and use of needle rollers.
lol yea thats me asking qs on my partners account.
Posted: Sat Jul 30, 2011 6:12 pm
by slide
I had wondered if it was you or someone on this forum....
I got my gearbox out today, might start stripping it tomorrow, or may be later in week after work each day
Posted: Tue Aug 02, 2011 12:45 pm
by icekayak
Looking at doing one of these...
any conclusions of best course of action?...
That place in New Lynn on Trademe has quoted me
$1250 for reconditioned box
$450 for replacement of bearings/seals/gaskets (Standard ones)
$600 for replacement of bearings/seals/gaskets (TM series? "outlast standard bearings by 50%")
$180 for bearings kit (didn't say if TM or standard)
all + GST
He said he can't get one of the roller bearings needed so no point in putting any in at all.
Posted: Tue Aug 02, 2011 7:43 pm
by will i am
icekayak wrote:Looking at doing one of these...
http://www.offroadexpress.co.nz/Forums/ ... 5&t=26681#That place in New Lynn on Trademe has quoted me
all + GST
i just bought some bearings off them, tm series for $180`
if i had heaps off money i would buy a recondition one but im to poor
have to pull my gbox out this weekend
Posted: Wed Aug 03, 2011 6:30 pm
by u13turbo
will i am wrote:icekayak wrote:Looking at doing one of these...
all + GST
180, does that include everything needed to rebuild? and is TM heavy duty?
Posted: Wed Aug 03, 2011 6:49 pm
by will i am
tm are meant to be a heavy duty bearing.
180 includes all main bearings needed to change and front seal and gasket
im still going to need to buy lock nuts and maybe rear seal if leaking
Posted: Wed Aug 03, 2011 7:20 pm
by Sketchy_Racer
For the lock nuts, if you have access to a lathe just machine 0.5mm off the face of it so the stake marks are 180 out from the old ones.
Posted: Sun Aug 07, 2011 7:40 pm
by will i am
will just buy new lock nuts if i can get hold off them.
project on hold for another month as we shifting house. comes with a double garage (beats squeezing everything in the single) and i bought a work bench on the weekend so gota mount my vice on it
Posted: Thu Aug 11, 2011 6:37 am
by will i am
got my bearing kit yesterday.
bearing numbers are:
tm306nr X2
tm305c3
tm204c3
22tm06c3
then theres a oil seal 30X45 or a part number of 400721
front gasket and a needle roller bearing.
would up load a pic but computer is slow old and broken.
if anyone can tell me the easyest way to upload a pic pm me
Posted: Mon Aug 15, 2011 8:03 pm
by slide
will i am wrote:bearing numbers are:
tm306nr X2
tm305c3
tm204c3
22tm06c3
Of the bearings in the kit you got, are they all ballrace bearing type? or are any roller bearing?
I've been trying to do investigations as to what the difference is between so called heavy-duty and normal kits. Worth knowing when HD kits are over $100 more..
Posted: Wed Aug 17, 2011 11:18 pm
by kiwinoz
Hi guys, lots of G/box chat here. Manual ones i guess. I have a d21 Pathfinder, with 2.4 petrol. I was wondering what G/box you guys have behind your TD27s?
Mine is a fs5w71c, smaller then what the V6 manual has. Had it recon last year, so hope it lasts a while, but after reading all your posts, I'm not so sure..
Don't know what bearings went in it.
Posted: Sun Aug 21, 2011 11:03 am
by slide
Probably is same gearbox as ours, just with different bellhousing to suit different engine
The v6 has a larger unit.
Nissan seem to make 2 general gearboxs (known as bigbox( FS5R30A ) and smallbox-(fs5w71c))
There are different variants and bellhousing/ tail housings different between applications
Posted: Sun Jan 22, 2012 11:43 pm
by wax
The d21 td27 has the fs5w71c
the terrano II has the FS5R30A
This fits in and you will not break it with the td27
You just have to find one. Here is the one going into my terrano before the weak one breaks. I will sell the orginal
