80 Series help
Posted: Sun Jul 24, 2011 10:12 am
by dskd
on the the lock up diffs should the lights on the dash flash or be solid on when the lockers are turned on ?
and what do they do and when can you use them ie
center does what and when do you use it ?
rear locks the back axel solid ?
front locks the front axel solid ?
i put all 3 in on a flat paddock and you could hardly turn
and what size speakers are in the front and back doors of a 91 vx ltd
thanks
Re: 80 Series help
Posted: Sun Jul 24, 2011 10:33 am
by skid
dskd wrote:on the the lock up diffs should the lights on the dash flash or be solid on when the lockers are turned on ?
supposed to be solid but mine flash and still engage and what do they do and when can you use them ie
without it the lockers wont work, transfers drive to both front and rear of vehicle, have found out lately that even on the simplest of stuff (clay track) you get nowhere, so it pays to engage when going off roadrear locks the back axel solid ?
correctfront locks the front axel solid ?
correct, but be careful as to when you use it, never on flat hill surfaces it has a tendency to flick you sideways. only use mine it rutty situations and really slow crawling over rocks etci put all 3 in on a flat paddock and you could hardly turn
with front one in it tends to lock up steering a bit, well it does in mineand what size speakers are in the front and back doors of a 91 vx ltd
shitty factory 20W ones, biff them ASAP
thanks
Re: 80 Series help
Posted: Sun Jul 24, 2011 10:43 am
by 1hamish1
#will flash when trying to lock after you turn button, then solid when they have locked
#Center diff allows front wheels to turn at differant speeds to rear on road when steering as its a fulltime 4x4 and this is to avoid breaking stuff. Center locked means even 50/50 drive between front and rear with no slip. Dont use on road. Always use offroad.
#yes stops slip in rear diff
#yes stops slip in front diff
#front difflock does this and it always will, as all wheels turn at same speed but outside wheels need to travel further than inside when steering, hence why having this engadged on solid tarmac etc will break stuff
#cant remember off hand
thanks
Re: 80 Series help
Posted: Sun Jul 24, 2011 6:04 pm
by dskd
thanks guys worked well today towed 3 out in the snow =)
Re: 80 Series help
Posted: Sun Jul 24, 2011 8:28 pm
by Mudde1
[quote="skid"][quote="dskd"]on the the lock up diffs should the lights on the dash flash or be solid on when the lockers are turned on ? supposed to be solid but mine flash and still engage
easy to fix, switch is on the diff head, needs a 25 mm deep reach socket to change, and $120 for a new switch.
Re: 80 Series help
Posted: Sun Jul 24, 2011 9:19 pm
by mudmike
If the switch is the same as mine is a reverse switch as used in most toyotas, cost me $20 from ripco. toyota wanted $300. lol.
