85 Hilux 4wd light not working
jagni401
Post by jagni401 »
Gidday,
I have brought an 85 Hilux and the 4wd light does not come up on the dash (assuming that there is one).
The 4wd engages fine, in both high and low, but no light.
Could it possibly just be a blown bulb/fuse?
Any ideas....
KIWI_TERRANO
Re: 85 Hilux 4wd light not working
Post by KIWI_TERRANO »
check the bulb :)
rayndeb
Post by rayndeb »
check the switch at the transfer case too
90 Landcruiser Vx 4.2 turbo 5 speed part time 4wd 75mm lift air lock in rear 35 Wranglers snorkel swaybar disconnects
Jarkko
Stropper
Post by Jarkko »
I had the same problem. Turned out my vacuum hoses where mixed up
