isuzu turbo question,
Posted: Mon Jul 25, 2011 11:01 pm
by nizmo
hi i have a little truck with a 4jb1 engine non turbo, it white smokes on start up and misses a bit but glow plugs are good, could this be injectors?? also can i bolt a turbo on from a turbo 4jb1?? and just adjust injector pump?
Re: isuzu turbo question,
Posted: Tue Jul 26, 2011 5:13 pm
by mud_slinger
white smoke? is it using any water? to me it sounds like it has water sitting in the cylinders could be head gasket, get it checked.
not sure if the the non turbo internals diff to the turbo model. if you do turb it use the turb injector pump . check out www.clubisuzu.com that place is a wealth of knowledge on isuzu stuff
Posted: Tue Jul 26, 2011 5:34 pm
by tweake
have you checked the glows are getting voltage as well as testing the individual glow plugs ?
Posted: Tue Jul 26, 2011 10:24 pm
by nizmo
mud_slinger wrote:white smoke? is it using any water? to me it sounds like it has water sitting in the cylinders could be head gasket, get it checked.
hi not useing water, at all, ill look in to it this week, thanks
Posted: Tue Jul 26, 2011 10:27 pm
by nizmo
tweake wrote:have you checked the glows are getting voltage as well as testing the individual glow plugs ?
good idea. ill do that, ill also check comprestion, the full story is we owned this truck about 3 years ago and after changing the oil on start up it smoked white and was missing, so i changed oil again and still the same it has been like this ever since, after about two years i got the truck back but want to get it sorted,
Posted: Tue Jul 26, 2011 10:55 pm
by tweake
the other thing is if its leaking oil out of the turbo. evaporating oil in the exhaust comes out white.
Posted: Tue Jul 26, 2011 11:28 pm
by nizmo
tweake wrote:the other thing is if its leaking oil out of the turbo. evaporating oil in the exhaust comes out white.
this is a non turbo one,
Posted: Wed Jul 27, 2011 10:02 am
by tweake
isuzu turbo question for a non turbo..... :lol:
otherwise try exhaust valve leaking oil.
