g'day all
i hame a clunking noise in front end of my 92 bighorn
i think it is coming from the auto hub (sounds bit like a cog jumping a few teeth) when 4wd is engaged
anyone got any idea's on whats it is / what to look for / solution to problem ?
cheers Aussie
clunking noise
Re: clunking noise
Hi There,
Seeing as they are Auto hubs I would get rid of them straight away as they are prone to give out at when least expected. If you do replace the hubs and it is still making a noise then it could be several other things to look out for like C.V's or the front diff.
Firstly have a look at the hubs.
Cheers.
Cheers.
aussie_matt
- Stropper
Re: clunking noise
ok thanks heaps mate... will try that...1st time i had anything to do with auto hubs an dont like em ..back to good ole manual hubs
cheers Aussie
cheers Aussie
