Buying a Surf
ice4x4
Buying a Surf
Post by ice4x4 »
My brother is looking at buying a 1989 Hilux Surf. Can any of you toyota boys give some advice on what to look for i.e common problems etc...
Many Thanks.
1988 Range Rover Classic
2010 Discovery 4 HSE 5.0 V8
bruntonjm
Re: Buying a Surf
Post by bruntonjm »
Hi, rust in bottom of doors, and on firewall and the rear quarter panals.
Rear window on tailgate plays up, but easially maintained with a new console switch and some silicon.
tweake
Re: Buying a Surf
Post by tweake »
what engine?
the 2.4 turbo diesel is well known for cracking heads and dual mass clutch is not a cheap fix. thats assuming they haven't been replaced already.
ice4x4
Re: Buying a Surf
Post by ice4x4 »
its a 2.5 TD
tweake
Re: Buying a Surf
Post by tweake »
ice4x4 wrote:its a 2.5 TD
either you mean 2.4 or its had an engine swap and you will need to find out the engine model number.
ice4x4
Re: Buying a Surf
Post by ice4x4 »
You are right (Bloody Land Rover Fools :roll: )
Its a 2446cc turbo diesel motor
tweake
Re: Buying a Surf
Post by tweake »
as before heads and clutch are the two big $$$$ things to look out for motor wise. at least it won't be EFI. makes it easier to do a 2.8 or 3.0 conversion.
also check out radiator, they do not handle overheating.
ice4x4
Re: Buying a Surf
Post by ice4x4 »
tweake wrote:as before heads and clutch are the two big $$$$ things to look out for motor wise. at least it won't be EFI. makes it easier to do a 2.8 or 3.0 conversion.
Thanks for the advice :wink:
