CV. Joint Terrano
For all Nissan related topics
minefield
CV. Joint Terrano
Post by minefield »
I have just blowen a front cv. joint in my Terrano, I'm haveing problems fitting the new one, The old one came out in peices I have unbolted the shalf off the diff undone the bottem nut on the wishbone I cant get the hub out there dose not seem to be enough movement ?
There must be a easy way HELP!!! :?
spankmeister
Post by spankmeister »
Hi buddy,
I have just finished doing my balljoints this weekend gone, and I found the only way to remove the CV axle, was to remove the upper balljoint, and then wriggle the axle out of the hub/disc. There wasn't much room, but I managed to do it.
Mike
minefield
cv. Joint Terrano
Post by minefield »
I have undone the bottem nut on the top arm the top boot seems to be atached or is just stuck ? When I tried to lift the upper arm up the ball joint boot appeared to be stuck , Whats the seceret
I was a bit worried that I would rip the boot, ?
DieselBoy
Post by DieselBoy »
In here is a list of all sorts of usefull links.
http://www.offroadexpress.co.nz/modules ... opic&t=889
Mid way down the page I think you may find just what your looking for :wink:
albundy
Rolly Polly
Post by albundy »
You need to undo both top and bottom ball joint, undo half shaft at the diff, undo shock and pull out of way, pull the whole knuckle out. I find this the easiest way as you DO NOT damage the boot and you can work with it all in a vice on bench. More work but worth it.
Al
