80 series diff head size
Posted: Sat Jul 30, 2011 9:53 pm
by Fakey
couple of questions
1.Just wondering if the 40 series air locker Ive got will bolt onto the ring gear from my 80 series lsd diff head?
2.Ive been meaning to put the locker into my original 70 series diff head, but I was also wondering if the 70 series diff head will bolt into the 80 series housing?
I havent had time to pull the 80 series diff head out to compare the two an I need two cruiser semi floater cross pins to repair my locker before its usable anyway
Re: 80 series diff head size
Posted: Sat Jul 30, 2011 10:24 pm
by sig
yep it will fit as long as they are both rears ( thou the early 70 fronts were the same too).might be interested in your lsd carrier if you want to move it on
Posted: Sat Jul 30, 2011 10:36 pm
by Fakey
sig wrote:yep it will fit as long as they are both rears ( thou the early 70 fronts were the same too).might be interested in your lsd carrier if you want to move it on
Cheers for the reply. Could be interested, lots of stuff to do before I look at the diff yet just pondering a few options at this stage
the rear lsd sucked last weekend
Another thing I havent looked at yet was wether the carrier bearings for the locker are the same/interchangeable as when I took it to brian he said it had the smaller carrier bearings (its an early roberts/ARB air locker)
On another note; do ya still want the mr2 rear brake set up?
Posted: Sun Jul 31, 2011 11:54 am
by sig
forgot all about that . yeah still keen .How much were they again !
Posted: Mon Aug 15, 2011 4:35 pm
by charo249
Try looking here:
http://www.arb.com.au/media/products/air-lockers/application_chart.pdf if they have the same model number for both it is interchangeable.
Posted: Mon Aug 15, 2011 4:53 pm
by badnuz
80 front run the same as hilux rear, 8 inch...... same as some prados etc etc
"cruisers" as in 70/40 etc are all 9 inch rear.
