whistling sound under acceleration
collaboration
Post by collaboration »
its v6 surf auto transmission
it makes whistling sounds on the first few seconds when i put my foot down on accelerator
this almostsounds like wind drafting through a hole
where should i look first?
DJ
Re: whistling sound under acceleration
Post by DJ »
hi check ALL vaccum lines for leaks
vinceparts
Post by vinceparts »
i had this exact same problem on my 1kz powered surf, it turned out to be the rear exhaust manifold stud had loosened and the exhaust gasses passing though the steel gasket made it whistle, really loud too, loud enough i couldnt drown it out with the factory stereo
