Finally figured it out , I was not highlighting IMG code when attempting copy.
Had it a couple of months after the misses pinched the 100 series of me.
88 Safari/Maverick with ford badge on the rear and Nissan on steering Wheel.
I have just fitted 33" Hankook MT with -20 offset rims so some homemade flares to come. 2" EFS Springs with OME shocks. Factory rear diff lock , PTO output but fitted with 12000lb Runva winch. Bit rough round the edges but running gear good. 4.2TD , Manual.
Still got 15 " rims with 31 " buckshots I may upgrade to bigger more aggressive muds , so probably a bit of guard chopping to do. Want to set up to do closest tracks around Coro.
Got Safari snorkle with it , just the outer bit so need to source or make internal bits.
Its got a nasty dent at back of roof from loosing a battle with a falling tree ( previous owner) , intial intention was to do a ute chop but stilling thinking about it .
Thats all for now
thanks
