Patrol / Safari / GQ PTO wanted
As in subject. PTO with shafts and lever or complete winch wanted.
Patrol L60 project
Re: Patrol / Safari / GQ PTO wanted
Finder wrote:As in subject. PTO with shafts and lever or complete winch wanted.
Still actual
Patrol L60 project
Keep an eye on the TradeMe site, usually have one on there
DaveM wrote:Keep an eye on the TradeMe site, usually have one on there
The problem is that i can't register on TradeMe, because I don't have NZ or AU post address.
I can only watch. I haven't got access to salers data
Patrol L60 project
Finder wrote:DaveM wrote:Keep an eye on the TradeMe site, usually have one on there
If you spot something you want info on, just post it in this thread, and I can ask for you.
thought a new listing of one was on there yesterday
here a good unit finder
http://www.trademe.co.nz/a.aspx?id=404362578
coxsy wrote:here a good unit finder
This is what I'm looking for.
Do any of You can get an e-mail to the seller, or ask him if he is able to send this set to Europe (by courier)?
Patrol L60 project
Patrol L60 project
someone on here should be able to track down the seller
Finder wrote:coxsy wrote:here a good unit finder
It wont be cheap sending to to Europe, And the PTO winch setup will be heavy.
Will cost more in shipping than the unit cost.
The unit will have to be fully cleaned and all fluids removed if going by air.
And will need a "Purge" certificate depending on the shipper (DHL wanted one for a part I sent to Canada)
Just an idea on costs, DHL to Canada 6kgs $470 NZD.
DHL had a special box rate if it fits in the box and is under 10kgs, $250 NZD.
Might be more cost effective to get one from Japan.
