245 hemi air intake size??
Posted: Thu Aug 04, 2011 9:58 pm
getting a custom air intake made up so i can move the air filter to between the wheel arch and the firewall. ill eventually run a snorkel.
the carbs has a 5" intake hole. does it make any difference really if i get a 4"pipe off the side which will reduce to 3" as it gets to the air filter. or should i just get 3" as the snorkel will realistically be 2.5" or 3"
its a 4L straight 6 for those of you who don't know
i know snorkels reduce performance generally so i want to keep as much air to the engine as possible.
