I have a factory PTO winch on my '85 Landcruiser with Steel cable.
I went 4wding last weekend and turned it into a block of mud inside and out.
After cleaning and swapping back to road tyres today I took it around the block and heard a big F'n snap noise.
Got out and found the cable snapped right by the hook ####!. This is weird because I hadn't touched it since the week before and I know it wasn't engaged. I checked the lever and found it won't go all the way into the óff' position, so I'm guess it got bumped while cleaning it out.
The question is, is there any way to get a new loop put in the end for the hook? If so, who does it in Wellington?
Snapped PTO steel cable, repairable?
1985 Toyota Landcruiser BJ73 with 13B-T
- ClassicCruiserSpares
- Sausage Shack
Re: Snapped PTO steel cable, repairable?
Go down to cookes and get another eye and thumble pressed on.
- mudlva
failing that purchase two staple and saddles to suit the diamater rope that you are using cooks will have the right size as well as the how to for installing them easy as
mudlva wrote:failing that purchase two staple and saddles to suit the diamater rope that you are using cooks will have the right size as well as the how to for installing them easy as
Dont use staples on a winch cable, its asking for trouble. If you have to go to cookes to by them take the truck and get then to do it properly while you wait. You should be able to get close enough to the crimper to leave the cable on the truck
What are you using as a shear pin, always had the pin go before the cable unless you had damage to it already. will pay to pull it all out and look for any damage. cookes will often do this before they put a new eye on it. they did when I got one put on my cable.
good luck
good luck
- mudlva
ok i might of called them the wrong name but there is nothing wrong with grips as stron as the cable and easily installed
heres a site that i found to show a picture
http://www.ropecentre.co.nz/general-har ... grips.html
been using them and cable tac'a'mans for years with no problems at all
as a side to this, winching over slack rope on the drum is what damages most rope but in our game its completely unadvoidable.
tac'a'mans are brillant for adjusting the lenght of wire ropes to excactly the right lenght as well as a cheep and easy way of doing a quick conection if a rope breaks.
mudlva wrote:tac'a'mans are brillant for adjusting the lenght of wire ropes to excactly the right lenght as well as a cheep and easy way of doing a quick conection if a rope breaks.
Is that what they call those cam lock style clamps, with the removable pin? I have two of those to enable me to use the Hi-lift as a winch (using my extension cables). Great for enabling you to pull from 1st layer on winch when need be
- mudlva
kbjj wrote:mudlva wrote:tac'a'mans are brillant for adjusting the lenght of wire ropes to excactly the right lenght as well as a cheep and easy way of doing a quick conection if a rope breaks.
yes they are a beaut piece of kit
meatc wrote:Dont use staples on a winch cable, its asking for trouble.
The left over half of ChCh is held together with these things
Cheers for the info everyone, I'll be taking it to Cookes to look at condition of cable and hopefully putting a new eye in along with a better hook.
mudmike: I use a 3mm high tensile cap screw. It may have broken the cable first because it was at an almost 90deg angle with the winch hook attached to one of the rated hooks (i.e. I wasn't actually winching at the time).
A mate uses the same cap screw and has had them snap before the wire.
