Are bighorn front A arms and axles longer than Mu
Posted: Sat Aug 06, 2011 10:36 pm
by ant-neil
have heard thru post on here that they are longer but have yet to here any coonfirmation
Cheers 4 any input
Re: Are bighorn front A arms and axles longer than Mu
Posted: Sun Aug 07, 2011 9:07 am
by Suza
I beleive that is true for example the tie rods on a 3.1 Mu are about 50mm shorter than a 3.1 bighorn.
A ggod place to double check though would be
www.clubisuzu.com
Posted: Sun Aug 07, 2011 6:51 pm
by Drurban
Yes they are my friend has Bighorn front running gear in his Mu and the front A arms are wider than mine(3.1TD Mu), tie rods are longer too, c.V are bigger aswell not to sure if they are longer only bigger diameter on spline.
Posted: Mon Aug 08, 2011 2:24 pm
by ant-neil
sweet thanks guys
havent started chopping up my MU
its a 2.8 auto
2.8 cos they suposed to be stronger
auto as i find it easyer accerating whilst mantaining traction and
trying not to wheel spin
ive got 32' simexs on her at mo
and just doing abit of home work before i do anything
how do i find out what diff ratio i have .
thinking either shackles or complete coil rearend from something .
thinking if i get a big horn front arms etc
why not just slap in the coiled rear while im there
this will just be a trailer baby so dents and shit no probs
just want to do as much of this as i can .
It want it to have a lil mopre clearance but a shit load more travel
but as light as possible
Anyother suggestions would be appreciated
this is my first build attempt so want to keep it relatively simple using readily available parts
Posted: Mon Aug 08, 2011 4:23 pm
by Drurban
Hey ant-neil,
As like the above post go to the site ClubIsuzu they are very helpful there nice bunch of people there, as for your build Iam sure there will be something on that site.
As for your Ratio I found out that I have a ratio 4:3 I had the diff head out so it was easy to find the ratio just by counting the number of teeth on both crown gear and pinion divide one by the other and there you have it for example in my case 43 teeth on crown gear and 10 on the pinion so 43 divided by 10 4.3 ratio.
Now to do it with out having to take diff head out is to rotate wheel once, count number of times drive shaft goes around divide number by 2, this is what I have been told to do, I have not tried this method myself.
Posted: Tue Aug 09, 2011 1:57 pm
by ant-neil
hmmm ok i was hoping it was just printed on the thing somewhere but its never that easy
so il jack it up and see how it goes
thanks for the tips guys
when i start chopping ill post as much as i can
(also kean to here of any other tips and stuff for the mu )
thanks ant.
Posted: Tue Aug 09, 2011 4:30 pm
by Drurban
Yeah I have not bothered to check if there is a sticker on the truck somewere or even in the engine bay, yeah I can agree with you noghting is never easy.
Anyway I will be watching this thread with intrest and looking forward to the outcome.
As for my Mu all I have done is suspension lift, body lift, 2.5" exhaust, future will intercool it up the boost a little and may be up the fuel.
Also were are you from?
Cheers.
Posted: Tue Aug 09, 2011 6:41 pm
by mud_slinger
on the options on the plate on firewall should say soomethin like 43g means its a 4.3lsd but only if it has it written under options.
i would check mine but im 15km from mine
Posted: Tue Aug 09, 2011 6:43 pm
by ant-neil
in taranaki mate
ive only just started getting to to 4wd abit more over the last year. had a V6 terrano went good but just getting to dented up so wanted some thing smaller and lighter (easyer to trailer) the terrano is gone now so the mu is getting the some hard loving
Im a share milker and busy calving for the next month so just collecting parts and getting ready to strip it etc after that.
im gonna move the tank up to the back seat as its getting to beatin up under neath. Any reason why i cant use a boat tank on a diesel.
oh and all back end cut back to end of leaf spring for straters , un bolt al rear section of the roof move battery to floor behind drivers seat and cold air box into glove box.
Posted: Tue Aug 09, 2011 7:42 pm
by ant-neil
yeah it isnt lsd
but maybe welded someday
good solution or not????
Posted: Tue Aug 09, 2011 9:27 pm
by mud_slinger
i wouldnt weld the rear either lsd it or buy a locker.
Posted: Tue Aug 09, 2011 10:01 pm
by Drurban
mud_slinger wrote:i wouldnt weld the rear either lsd it or buy a locker.
x
2 I would get a good second hand LSD and chuck that in the back you wont believe were your truck will go with an LSD, then if I were you start saving up for a locker.
Posted: Tue Aug 09, 2011 10:08 pm
by mud_slinger
my lsd makes a big diff. weld the front diff, that works a treat
Posted: Wed Aug 10, 2011 10:42 am
by ant-neil
yup jury is unanimous lsd seems to be the way to go
and what would the best 4 this on a budget
anyone have one sitting out back in a shed
Posted: Wed Aug 10, 2011 5:55 pm
by mud_slinger
jump on tard me and look up horse nutter. he is my wrecker and he is well priced and will sort you out
Posted: Thu Aug 11, 2011 10:41 am
by CRAZYBUSTARD
weld it its free
Posted: Thu Aug 11, 2011 4:19 pm
by mud_slinger
weld is crap on the rear
Posted: Tue Aug 16, 2011 2:43 pm
by ant-neil
Why is weld shit in rear
and doesnt welded front have more negative affects than possitive
