1kz-te power upgrade
mikee
Post by mikee »
Hi does any one know if any performance chips are available in New Zealand or if any one can build one,thanks.
DDAN
Re: 1kz-te power upgrade
Post by DDAN »
charlies paj
Post by charlies paj »
Nz new or jap import ? computer plugs are different i think
kbushnz
Post by kbushnz »
charlies paj wrote:Nz new or jap import ? computer plugs are different i think
Plugs should be all the same.....
Upgrade chips are now not as widely available as the newer D4D spec engines are out there.
The chip from Aussie is sooooo over priced.
I have been hunting but no luck. Its cheaper to get a manual pump made up than do the chip mod.
DDAN
Post by DDAN »
I went with the manuel pump so much more scope with what you can do, man it wakes these engines up
snork
Post by snork »
can you tell me more about these manual pumps...who does them , how much . any other mods needed?
SamLogan
Post by SamLogan »
i have one too and they give the engine some serious balls. Give nathan at kiapoi repowers a call and he should be able to sort you out. As for other mods you need a bigger exhaust, exhaust gas temp gauge and a boost gauge as you need to do a bit of tuning. Best to give Nathan a call though.
Sam
