badnuz wrote:sounds like one bad battery... do you dive it regularly? the Calcium style mainatnce free need decent (read hi) current to keep them fully charged. if your not driving it evry day or so then the batteries will just be slowly draining away. it may suggest your alternator needs an overhaul but i would suggest you get it professionaly checked
and if you need new batteries fit good ole lead acids, they can handle low rpm low voltage chaging etc etc
my thoughts anyway
Ok sweet yeah thats my thoughts. I use it once every couple of days and its always started sweet as. It started sweet as this morning and is running and the guages are back to normal but the indicator guages are still the same so might pay to put them back on a slow charge over night to get some charge back into them. I prefer the old lead acid batteries for that same reason.
kbushnz wrote:First thing to check is the alternator output, make sure its sending the correct charging voltage.
Then connections.
Then if that's all good, the batteries could be on the way out.
As you are 24V and use two batteries, pays to change them in pairs.
Calvin
Yeah I might get a mates volt meter as I dont have one. Yeah I know the connections on one of the batteries werent the best so I re did that one and one of the batteries are new and the other one looks about 12months old
muddy wrote:Do you have anything like stereo, air pump, etc running 12V taken from just one battery? That'll cause overcharging of the other and and kill it over time. Need to use 24V feed through a reducer to keep an even drain on both batteries
At this stage there is no stereo or anything that will drain power. haha the only mode of music is my ipod with a seperate speaker its doing the job just haha. I will probably get them on the slow charge tomorrow and see how they go after that.
Cheers for the suggestions
much appreciated
