Hi i have a nissan terrano 3L V6 1988
theres water leaking out by the bottom pully i dunno if thats the water pump or what? bloody thing does anyone have any idea what it could be?
and how hard it is to fix?
Blown gasket?? help!!
I did the one in my Pajero V6 which was right down in the elbow of the V and had a lot to strip out of the way to get to it but other than that pretty straightforward, just a case of carefully removing everything in the way, sticking the pump and new gasket in and bolting everything back.
Not too many bits left over afterwards and it didn't leak.
;-p
WarKu wrote:Easily fixed?
pretty easy if you have a little mechanical know how and are carefull you should be able to get the job done.
bout 1hr to clear all the shit away from around it and another hour to remove and clean the block surface ready for the new gasket and pump(use silicone on the gasket as well)then another hour to rebuild it.and use a good coolant
but wheres the fun in that
