Hilux sagging rear end
brakes-shocks-lockers-etc
jagni401
Post by jagni401 »
Gidday,
The rear end is sitting a bit low on my ute. Would I need to get new leafs, or just get extended shackles??
Something like this perhaps?
http://www.4wdbits.co.nz/ProductDetails ... uctID=3815
tomsoffroad
Flopsie
Re: Hilux sagging rear end
Post by tomsoffroad »
Extended shackles will lift it back up but will encourage laterial movement in rear diff. Cos your springs have flattened out extended shackles will also make the suspension softer in the rear. Great if your after good flex but not so great if you carry heavy loads. :wink:
rokhound
Post by rokhound »
You can also look into the idea of helper coils.
These sit between the chassis rail and your existing spring pack. I made some up for my old 60 series coozer and they were great, (and best of all, really cheap if you do it yourself) :P
Cameron
Post by Cameron »
send them to a spring joker and get the arch reset?
jagni401
Post by jagni401 »
Any ideas of a good spring place in Dunedin to get the leaves reset?
juz
Post by juz »
Brown and Cope
36 Maclaggan St
Dunedin
Phone: 03-477 8136
cheap as and usually drop off in the morning pickup same arvo.
jagni401
Post by jagni401 »
Cheers for your help mate
