SJ413 Transfer Case into a SJ80 Coily Zuk...
Posted: Mon Aug 22, 2011 2:11 pm
by fonz
Hello,
Wondering if anyone has or knows of any links to forums where they have put a SJ413 transfer case into a 1998 SJ80 Coily Suzuki?
Basically just after what was required to getting the 413 t/case in and mounted correctly.
Looking to get a lower ratio in 4x4 Lo.
Thanks in advance
Re: SJ413 Transfer Case into a SJ80 Coily Zuk...
Posted: Mon Aug 22, 2011 4:04 pm
by mudslut
I ran a 84 410 Tcase in my coily with 413 flanges on the Tcase and all the 413 drive shafts.Then i drilled the coily diff flanges to suit the 413 drive shafts,the front drive shaft did need a 50mm spacer(i still have one if you need one)
Dan
Posted: Mon Aug 22, 2011 5:52 pm
by suzookyman
If your going to the hassle of changing the transfer case why not chuck in a sj410 one, it is the better option at the end of the day.
Al
Posted: Tue Aug 23, 2011 12:58 pm
by fonz
Thanks. You're right in saying the 410 case be better. Mudslut, I will PM you about the spacer once I got everything sorted.
Do you know if the mounting points the same? Or what needs to be done here....?
Posted: Tue Aug 23, 2011 2:52 pm
by mudslut
The mounts on the chassis are the same
