Prado auto trans troubles
Posted: Mon Aug 22, 2011 8:02 pm
by koma
I've got a 96 90 series prado, its really harsh in the gear shifts. Especially when hitting overdrive, or shifting up from 1st to 2nd manually etc. The trans has had a flush and filter change but it hasn't helped, any ideas on where to go to from here? Thanks in advance.
Re: Prado auto trans troubles
Posted: Mon Aug 22, 2011 8:18 pm
by kbushnz
Perhaps the line pressure is too high.
I think they are controlled electronically in the 90 series via a solenoid.
Check all the wiring, pull the plugs clean with contact cleaner, once evaporated plug back together.
In the earlier 70 series it uses a pull cable.
Calvin
Posted: Sun Aug 28, 2011 8:52 pm
by koma
Cheers, i had that thort as well and gave it a crack. Thought it was mint but seems to be back to its old tricks. Can't work it out, some times its mint and other times its rough.
Posted: Sun Aug 28, 2011 8:56 pm
by kbushnz
Could also be the ECU, uses one unit for engine and auto.
Caps have a habit of crappn out anytime after the ten year mark.
Posted: Mon Aug 29, 2011 11:20 am
by jeremy
Not sure if this is any help to you... but we had a similar problem with our lexus auto - harsh shifting down into 1st - it turned when the box was rebuilt, the guy forgot a ball bearing from somewhere in the valve body. Got it put back in and it was back to normal.
