Hi
Looking for a cheaper timing belt than what repco are charging
Repco - 220+
super cheap - $163+
Does anyone know where to find them cheaper anywhere?
daihatsu Rugger 1990 2.8dt Rugger
Engine: DL-60
chassis: F76-031233
On the belt is:
0-14 13568-87306-Powergrip 108RU32
In the rebuild manual is:
DL 42.52
Pitch Peripheral length 1028.7 mm
Pitch 9.525 mm
Num of teeth: 108
Belt width: 31.8 mm
Belt thick: 5.4mm
Only a mud truck so dont wana to pay that if i can help it.
any ideas or places to try much appreciated
Cheaper Timing Belts anywhere?
- muddyhilux
Re: Cheaper Timing Belts anywhere?
just called saeco through work account,wil see what they come back with,normally get pretty good discounts
i have found partmaster the cheapest (with trade discount)
http://www.ebay.com/itm/DAIHATSU-RUGGER ... 45facf3f7a
You may need to get a quote on freight, but still under $100 NZ......if you don't mind using ebay
thanks for the tips and places to look, just looking at the moment as got to do a couple of other projects first.
Have you tried Toyota? they have some reasonable fixed pricing on common stuff like this
- mud_slinger
try STA parts in auckland really good to deal with
needs more curry
0272593533
0272593533
