Hey guys Im trying to find an R150f.
What trucks did they come out in? V6 petrol?
Anyone have one for sale?
Jarrad
R150f boxes
Re: R150f boxes
have a look on trademe the come up on there a bit sometimes people dont know what they got and the go cheap
Re: R150f boxes
Jase, what would you have to pay for one ? If it was cheap ? and if it wasn't cheap
FITZY.
FITZY.
Re: R150f boxes
ive seen them anywhere from 100 to 600 on there just a case of waiting if it isnt urgent
Re: R150f boxes
Yea it comes in a few trucks. Look for ones with these engines V6 3VZE and 5VZ-FE. What the diff between the R150f and the R151f apart from 1st and 2nd ratios being lower in the R151f? Are the bolting patterns different? Is there a difference in strength?
Re: R150f boxes
No difference in strength just want the 150 ratio.
Re: R150f boxes
http://www.trademe.co.nz/motors/car-parts-accessories/toyota/gear-boxes/auction-401913116.htm
doesnt say but pretty sure it is dont quote me
Re: R150f boxes
Yea thats one Im looking at. Im just getting him to check.
Re: R150f boxes
http://forum.ih8mud.com/79-95-toyota-tr ... r151f.html
http://en.wikipedia.org/wiki/Toyota_R_transmission
.151 = 4.31 first
150 = 3.83 first
I *think*
Both are 23 spline outputs, but don't forget that the 150 has a different bolt pattern, so you need an adapter to bolt it to a gear drive 4-cyl tcase... 151 doesn't need this adapter
R150
A 2WD transmission found in many Toyota trucks. It came with two input shaft lengths pre- 1996 and 1996 and up.
Ratios:
First Gear: 3.830:1
Second Gear: 2.062:1
Third Gear: 1.436:1
Fourth Gear: 1.00:1
Fifth Gear: 0.838:1
[edit] R150F
A 4WD transmission found in many Toyota trucks. [V6 3VZE and 5VZ-FE]
Ratios:
First Gear: 3.830:1
Third Gear: 1.436:1
Fourth Gear: 1.00:1
Fifth Gear: 0.838:1
[edit] R151F
A 4WD transmission found in only two model years of Toyota trucks(not avilable in 4runners). [Turbo 22-RTE 1986 and 1987]
Ratios:
First Gear: 4.313:1
Second Gear: 2.330:1
Third Gear: 1.436:1
Fourth Gear: 1.00:1
Fifth Gear: 0.838:1
