Terrano front tie rods
For all Nissan related topics
minefield
Post by minefield »
On my last 4wd trip I blew my cv. joint also bent both tie rods, I don't know weather its because of the tires I am running [32x10.50 mongrules , Any one know if there are tie rods from another 4wd that are heaver and can be made to fit . Thanks :?
jumper
Post by jumper »
i have busted quite a few tie rod ends 32x10.5x15 simexs :twisted:
since i put on an idler arm pivot brace i have not bent one tre
The idler arm pivot had bent and allowed the castle nut on the inner tre to hit the frame and wore half the nut away. i think this put extra stress on the tre.
i copied this but in reverse
i don't think there are any tre that have the same taper and are heavy duty.
minefield
Terrano tie rod
Post by minefield »
I have a brace on the bottem the idler arm it still did not help regarding the tie rods I may even see a engineer if he can make something up that won't bend,
I like your support bracket , diferent to mine as mine comes off the chassie and bolts to the bottem of the idler arm,
Do you have a intercooler? if you do,dose it make much differance
Also do you have much problems with cv's
Graham :D
