Simex, Silverstone, Beadlocks, axle, and truck weights.
churchill
Post by churchill »
I'm after the weight of some of the following items if anyone could help me:
Cruiser or hilux front beam axle hub to hub with brakes.
Cruiser or hilux rear beam axle hub to hub with brakes.
15x10 steel rim with beadlocks.
35" Simex extreme trecker of Silverstone MT117 Extreme tyres.
Overall weight of a trials truck C-class or D-class.
They dont have to be overly accurate so off the top of your head will do for now.
mudlva
Re: Simex, Silverstone, Beadlocks, axle, and truck weights.
Post by mudlva »
cant help with the weight apart from to heavy for me to lift if you have an old set of scales i have the for and aft diffs sitting on the ground at the moment most welcome to head over and weight them direct
ClassicCruiserSpares
I think from memory the hilux front diff is 140kgs, the cruiser about 160kgs, cruiser rear 140kgs and 35simex 35kg per tyre with rim.
These may not be exact figues but are close. :D
Last edited by ClassicCruiserSpares on Wed Aug 31, 2011 6:00 pm, edited 1 time in total.
churchill wrote:I'm after the weight of some of the following items if anyone could help me:
Cruiser or hilux front beam axle hub to hub with brakes. dunno bout axles but my 80 series weighs 2500kg all up
15x10 steel rim with beadlocks. about 15kg
35" Simex extreme trecker of Silverstone MT117 Extreme tyres. about 15kg
Overall weight of a trials truck C-class or D-class. last one I sat in was 1230kg, cruiser diffs steels wheels 35" kumho's, supercharged commy V6 but most are between 1000-1400kg dpending on lots of different stuff
wopass
Post by wopass »
skid wrote:1000-1400kg dpending on lots of different stuff[/color]
like how many pies you ate before hopping in... :lol:
MNC
Post by MNC »
Or how bad you sh!t yourself going up a vertical cliff on the last hazzard!!! :lol:
churchill
Post by churchill »
Brilliant guys, thats bang on what I need. I'm keen to head out with some weigh scales not this weekend but the following one mudlva if you don't mind.
I thought the trials trucks would be lighter for some reason, must be too used to race cars.
Need to start using carbon fiber for chassis!!
Thanks
mudlva
Post by mudlva »
churchill wrote:Brilliant guys, thats bang on what I need. I'm keen to head out with some weigh scales not this weekend but the following one mudlva if you don't mind.
Thanks
next week end is fine at the moment give me a text midnext week and go from there
dool forgot the number
021 599 519
churchill
Post by churchill »
Thanks
021 599 519
Will give you a call next week, cheers.
4WDbits
Post by 4WDbits »
Just weighed some tyres:
36/12.5-16 Simex ET is 34kg
35/11.5-15 Simex ET is 33kg
33/10.5-15 Silverstone MT117 Xtreme is 24kg
churchill
Post by churchill »
4WDbits wrote:Just weighed some tyres:
Brilliant, good data. Thanks.
