GQ wheel nuts loose, torque settings??
For all Nissan related topics
muskie
Post by muskie »
i am sure my front wheel nuts are working loose, whenever i go to take a front wheel off they never feel that tight and undo fairly easily, they were always ok with the old standard wheels its only since i put new 15x8 steels on... anyone know what the torque setting is off the top of there head???
Re: GQ wheel nuts loose, torque settings??
106nm
118-147nm ex manual
u13turbo
Post by u13turbo »
get a power bar and go hard.
slide
Post by slide »
Just checking, but did it have alloys on it before? If so, are the wheelnuts themselves got the normal taper on them? Some alloys have stepped nuts that wouldn't have the contact area to stay tight.
Could be easily overlooked
muskie
Post by muskie »
slide wrote:Just checking, but did it have alloys on it before? If so, are the wheelnuts themselves got the normal taper on them? Some alloys have stepped nuts that wouldn't have the contact area to stay tight.
wheel nuts are from the stock steel rims fitted from the factory so should be ok.. i will try the correct torque setting (thanks coxsy) and see how they go.
oldblue
Post by oldblue »
Make sure that there is no paint, grease or oil on the countersinks .
charo249
Post by charo249 »
If wheel bearings have a bit of slop in them - this can loosen wheels nuts especially if those new wheels have more offset and bigger tyres mounted on them.
muskie
Post by muskie »
charo249 wrote:If wheel bearings have a bit of slop in them - this can loosen wheels nuts especially if those new wheels have more offset and bigger tyres mounted on them.
done wheel bearings up slightly and regreased today, now running 35'' with 8'' rims so all could be related, torqued up. will give them a week and re torque.
badnuz
Post by badnuz »
i think sir greald had the same issue, turned out to be the hole diameter on his steel rim was 1mm to small? i cant find the thread but its here somewhere..... maybe PM him?
