Winch/Bullbar ARB Style/Type. Any Recomendations?
suzukisport
Re: Winch/Bullbar ARB Style/Type. Any Recomendations?
Post by suzukisport »
Helps if you have your location on your details :wink: ARB stores around NZ, badnuz would be the guy to talk to for prices and details.
you'll get one through any ARB dealer but you'll probably want around $2k is in your back pocket when you go down to pick it up
Ralfie
Post by Ralfie »
Contact your mearest ARB agent
Phone 0800 ARB 4WD (0800 272 493)
http://www.arb4x4.co.nz
ClassicCruiserSpares
Not sure what sort of truck you want it for but this is cheap!! http://www.trademe.co.nz/Browse/Listing ... =403489558
SMOKEY
Post by SMOKEY »
Caleb, unless you have the talent and skills to make a repair on a damaged bar you will be wasting your time, I have repaired mine twice now and when it gets hit it ends up back in it's damaged shape, they need to be cut and rebuilt to lose the memory, and if you have those skills for the money they want you might as well start from scratch. And if you are paying you will find 2K won't go far by the time it is manufactured and coated.
GOOD LUCK,
FITZY.
DaveM
Post by DaveM »
About $1500 for an Ironman winch bar new.
callum007
Post by callum007 »
the cheap Iron man bar I thought was $1350 and the dearer one $1750. Why dont you try Ron at Kiwilink Imports.
I believe his are identical to Ironman, but even cheaper.. I think they come out of Russia.. But are Airbag compatible etc, so unless someone has one that has been crap...
rokhound
Post by rokhound »
I have a top of the line iron man bar on the playdoh. Seems to be a well made unit, not that is ever really likely to see serious action on the pussy truck.
If you have an airbag equipped rig, you have no option other than to buy an airbag compliant bar, (unless of course you want to spend moonbeams on crash testing your own design).
vvilly
Post by vvilly »
Or if ya truck older than 9/97 remove the airbags and get it certed :D :D :D :D :D
Return to “Tool Shed”
