Time to change
MATT4U
Time to change
Post by MATT4U »
Watch this space.................................. :pirate:
turoa
Pyro Junior
Post by turoa »
you're buying a land rover? :lol:
MATT4U
Post by MATT4U »
HELL NO.
With a comment I think i need to give a hint
hosehustler
Post by hosehustler »
:cheers: 5MGEU or IGGEU, or 1G, c'mon spill the beans :batman:
I hate signatures
monaro427
Post by monaro427 »
thats got a 5m in it, it was on trade me, so have ya got a bellhousing for it yet or are you gonna get one made up,
MATT4U
Post by MATT4U »
Yep its a 5m, paid the deposit and pick it up on sunday.
i going to have to get a bellousing made up
SupraLux
Complete Bastard
Post by SupraLux »
Sweeet... welcome to the ranks of fuel-guzzling mud-slinging loud-pedal-thrashing madness :) (In a very tread lightly and ecologically friendly way, of course :P )
Craig, you still got that old 3Y flywhel and clutch? You might be able to get your beers back, methinks... :wink:
Steve
zigen
Post by zigen »
Matt4U, i noticed you were on toyspeed - another toyota forum, mostly based around cars rather than 4wds, send the following people PMs are they possibly know where to score an M series bellhousing from; deaf_rattle and myKool, could also possibly try nite_b.
alternativley, make the auto bellhousing fit the manual box, usually works out cheaper than getting one made up.
MATT4U
Post by MATT4U »
Thanks to craig I now have a flywheel and clutch, Steve what condition is the clutch??? will i need a new clutch
SupraLux
Complete Bastard
Post by SupraLux »
I wouldn't have a clue... it was a long time ago I gave it to Craig, and a long time befor ethat I got it...
Have a look at it, is there meat on the plates?
I'd possibly look at getting a new clutch for it, but on the budget I'm guessing you are using here I'd just chuck it in and see how it goes... its only an afternoon to change it if it doesn't have enough clamping force for the loud pedal thrashing it will likely get :)
Steve
MATT4U
Post by MATT4U »
Update, I fierd it up tonight in the car, I had to set teh timing as the guy I brought it off fucked it up.
Tiz all good now though, time to pull it out!!!!
MATT4U
Post by MATT4U »
Closer, Engine out of the lux, engine out of the supra, Flywheel in getting modded, Radiator in getting modded :twisted: :twisted: :twisted: Getting closer :twisted: :twisted:
niblik
Post by niblik »
sweet matt...
any pics of progress so far?
p.s.... ya didnt soil up the landlords garage did ya?...... :wink: :lol:
MATT4U
Post by MATT4U »
Na I did it at craigs place "Monaro427"
No pics yet, just wanted to ge it done
hosehustler
MATT4U wrote:Closer, Engine out of the lux, engine out of the supra, Flywheel in getting modded, Radiator in getting modded :twisted: :twisted: :twisted: Getting closer :twisted: :twisted:
where you getting the radiator done :?:
I hate signatures
MATT4U
Post by MATT4U »
A1 Radiators, Did a bit of a name drop and got it cheep :P
So today I picked up the radiator, Flywheel and new flywheel bolts
hiriklux
Post by hiriklux »
watch those flywheel bolts they end up in the funniest of places :twisted: :twisted:
MATT4U
Post by MATT4U »
Yea I gather that, I think I'll keep them in the bag untill they are needed and keep you away from them
hiriklux
Post by hiriklux »
:evil: :twisted: :twisted: :twisted:
mudchuka
Post by mudchuka »
how long will this engine last... should we have an ore wager?
MATT4U
Post by MATT4U »
Now thats not fair :cry: :cry: :cry:
Insky
Post by Insky »
mudchuka wrote:how long will this engine last... should we have an ore wager?
lol y nt ha 5 months :lol:
MATT4U
Post by MATT4U »
MATT4U
Post by MATT4U »
First run here
Still have a few things to sort but it runs!!!!
Steve_t647
Post by Steve_t647 »
But for how long? what was all the smoke from? were you running two stroke or had the engine sat for a long time?
Good work and good luck
wopass
Post by wopass »
Steve_t647 wrote:But for how long? what was all the smoke from? were you running two stroke or had the engine sat for a long time?
be greasy hands all over the exhaust manifold i bet :wink: same as any engine swap.....mine included :twisted:
MATT4U
Post by MATT4U »
there is still a little bit of diesel in the fuel, lol. It only smokes at hige RPM and even then it don't blow bugger all now :lol: :lol:
there was an oil leak but I have found the source of that now and its an easy easy fix :lol: :lol:
MATT4U
Post by MATT4U »
Time for an update, I have been spending a bit of time in the shed workin on the truck this week. Mainly just finding faults and fixing them.
I had a oil leak that was from an oil gallery.
and today I found the thermostat housing was held onto the head buy one bolt so when I got the watersystem under pressure it started pissing out, that gave me a hell of a fright, I was glad to find a bolt missing.
With all teh bolts missing and other stuff the guy I got it off was a big muppet.
I also found the heat exchanger on the airintake was leaking on the inside, easy fix, Bypass it, :twisted: :twisted:
so all going to plan, I mite have a test drive tomoro night :twisted: :twisted: :twisted:
safari_mulisha
Post by safari_mulisha »
i know how those lost flywheel bolts go..
i lost one of my 6 to fit my chromoly flywheel
so no bolting my tilton triple plate on till i found it took me 2 weeks
i went insane while doin so
MATT4U
Post by MATT4U »
Well had a bit of a set back, It should have been time for a test run on friday but it wouldn't run, at all. several days, new plugs and lots or swearing later thinking about possiably having to rebuild the entire engine Mike came past and traced it back to a faulty temp sensor for the injector timing. So now I can put everything back that I pulled off and get it on teh road!!!!
