Hi gang,
I was wondering if you can put a 1kz engine into a LN130 without changing the engine mounts ?
Are they the same or would I have to do some serious changes ?
I was thinking about replacing my 2lte with a 1kz, but if its too hard or too much work will put up with it a bit longer !!!
Cheers in advance
G
1KZ Engine Question
Re: 1KZ Engine Question
only have to move mounts on chassis, easy job
Dont forget you will need to wire the 1KZ you will need a loom to get the computer to run
i think theres a good write up on the AU surf site.
Woudlnt it be cheaper and easier to just buy a 1kz surf?
- crazyclark31
why not just put a 5l in and turbo that? Thats what i'd do.
Cheeper to buy a surf with the motor in it or do a lexus conversion, everything is bolt in.
need to cut and move mounts for 1kz and need to completely rewire truck,
Not if you get rid of electronics & use manual fuel pump. I have just done it & it was real easy. Now have heaps of grunt in my Bundera.
