10/11 September
10/11 September
hehehehehehehe starting the weekend early
was my last day of working for the supercharge battery man today and holy heck did it drag out
but its over and a long weekend awaits
so its off to the mountain snowboarding we go and then spend some quality time with my daughter then pick up our new puppy before starting the new job on monday
woot woot :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
petefj40
Ms Daisy
Re: 10/11 September
Post by petefj40 »
Nice one skid. Enjoy your time with your daughter in the snow. Lucky bugger.
Finishing one job and starting another is always an unsettling time. Hope it goes well.
Long weekends are cool.
I've loaned my pad out to my step daughter for her 19th birthday party this weekend. I'll be the bouncer on the door all night. It's fancy dress so should be entertaining..
I think I'll be the first one starting the weekends achievements for the 17th. It's Dunedin's Winch Comp that weekend. SO looking forward to it. :mrgreen:
Re: 10/11 September
been pissing about and learning about clutches the past week, have made 4 trips out to the clutch place at 100km per round trip :x and have gone through 4 pressure plates until we think we've found something that will work. After talking to a few people I flagged away the original 12" chev clutch that came out of the truck, it was rebuilt not that long ago and its not strong enough its down to 2400 psi clamping pressure already. My old 11" flatdeck chev clutch that spent 4 years only going to church on Sundays still came up pretty good but I got my hands on 2 centreforce pressure plates with centrifugal counterweights on the diaphram, one of them turned out farked coz its been running the wrong release bearing and the other one was almost brand new, still had the factory machining marks on it and was only pulled out coz of a clutch plate problem and the whole lot was replaced, they pulled it apart and machined it anyway coz there was a couple of heat spot marks on it. They gave me one of those dual friction$$$ clutch plates with the segmented side that’s supposed to concentrate the clamping pressure to improve its holding capacity so we’ll see how well that works?
SP450andLE
Re: 10/11 September
Post by SP450andLE »
I will be attempting to get the Lada going.
The Dizzy cap, points, condensor and rotor were supposed to show up this morning. But they didn't.
Someone knocked on the door after dark, turns out the Lada stuff was delivered to 106, not 103. But the package said 103. And it was also signature required, so who the fark signed for my Lada stuff? :evil: :lol:
Good on ya NZ Couriers :roll: :lol:
wopass
Re: 10/11 September
Post by wopass »
Sadam_Husain wrote:centreforce pressure plates with centrifugal counterweights on the diaphram, They gave me one of those dual friction$$$ clutch plates with the segmented side that’s supposed to concentrate the clamping pressure to improve its holding capacity so we’ll see how well that works?
i run a duel friction throw out weight centre force and it seemed to hold up ok when it was on my 383 motor so you should be sweet as with it in the 350...hope it holds on my new one
phraza
Re: 10/11 September
Post by phraza »
Not sure what i'm doing this weekend yet, but probably hungover on Saturday from the opening night of the RWC in Auck city on Friday. Might attempt to clean more of my Jeep! Then work Sunday. Yippee.
2WD 06 Hilux... for now
Re: 10/11 September
add a 1/2 pipe on the aircleaner for rocker breather, when in place heaps of room for the pipe , but can't get it in there with it on, oh on means welded, :roll: new location found do that tomorrow
Re: 10/11 September
Beer Cruiser and Suzuki1k came around this avo and we setup the new clutch and stuck the engine back in, its a slightly deeper clutch and a longer release bearing/carrier so had to do a bit of measuring and guessing to make sure the clutch fork could travel back far enough so the release bearing wasnt loading up against the pressure plate but it all worked out sweet, it only needed a wee bit of pushrod adjustment to get it all right in the end, had the truck started and the clutch tested in the shed, only got all the loose ends to tidy up now then stick the bonnet back on :mrgreen:
wopass wrote:i run a duel friction throw out weight centre force and it seemed to hold up ok when it was on my 383 motor so you should be sweet as with it in the 350...hope it holds on my new one
yeah I'm picking it'll be sweet now, theres a couple of LT1 chev trucks down here with centerforce clutchs and they are swearing by them :P
kbushnz
Re: 10/11 September
Post by kbushnz »
Got off work early today, contact laminated some glass to the area where I want to make a door thru the floor to get access to the PTO shear point.
Shot out and got some nibbles and booze for tonight's game and off early sat to get some new tyres on the van. (failed WOF) :(
Sunday might get the truck ready for next sat in woodhill.
Dr_PC
Re: 10/11 September
Post by Dr_PC »
Just finished loadding up ready for tomorrow morning early start Whangarei Club members are off to Woodhill, Give the Shore boys some recovery work to do
SP450andLE
Re: 10/11 September
So far, I have got the Lada running, got the timing a little closer to perfect, and play around with idle and all that.
All I need to do now is sort out fuel mixture, and the brakes. And the accelerator cable. And the niggling rust. And buy some new ignition leads. And better sparkplugs. And fix whatever else breaks in the meantime... :lol:
Re: 10/11 September
rocker cover breather now hooked in to low part of aircleaner, oil leak sealed after a good drive smell of hot paint not hot oil, may duck out early tomorrow and see if i can score a wof :D
suzookyman
Re: 10/11 September
Post by suzookyman »
Dr_PC wrote:Just finished loadding up ready for tomorrow morning early start Whangarei Club members are off to Woodhill, Give the Shore boys some recovery work to do
Are YOU planning on getting stuck Dan :lol: :lol: wish I could go but have a date with a clutch :(
Al
suzookyman
Re: 10/11 September
Just picked up my honed fly wheel, heavy duty clutch and new bearings ($$$ouch) will put in tomorrow :D ,.............GO THE "AB"s :D
Dr_PC
Re: 10/11 September
Post by Dr_PC »
suzookyman wrote:Just picked up my honed fly wheel, heavy duty clutch and new bearings ($$$ouch) will put in tomorrow :D ,.............GO THE "AB"s :D
IF IT HASN'T GOT A MOTOR ITS NOT A REAL SPORT
suzukisport
Re: 10/11 September
Post by suzukisport »
Picked up the truck from the auto sparkeys at 5:30 this arvo for Woodhill run tomorrow. Hopefully it goes good :D
suzookyman
Re: 10/11 September
Your a hard man Dan!
rokhound
Re: 10/11 September
Post by rokhound »
The other way to put that is "Most sport requires one ball, Real sports require 2!" :lol:
wellsie24
Re: 10/11 September
Post by wellsie24 »
fixed the axle seal in the hilux has been leaking for a few weeks now also did rear brakes cause they havnt worked in ages 2 tires and got the old man 2 slap a wof on her few drinks afterwards was bloody good
tweake
Re: 10/11 September
Post by tweake »
fitted the catch can. did some rearranging with inlet pipes. fixed car alarm so its now working.
fired engine up and out came the oil. so fixed few oil leaks.
SP450andLE
Re: 10/11 September
Ground down all the rust I could find on the body of the lada, and primed it ready for skimming, then eventually painting.
My mate and I had an idea of painting it bright pink and orange, just to add that in-your-face element to it. :lol: Comments on that paint scheme are welcome...
sibainmud
Re: 10/11 September
Post by sibainmud »
Leave a bit of black like wide masking tape strips, then we can name it "The Liquorice All-sort" :lol: :lol:
Still won't make me want one. Hate Liquorice :P
FORGE1
Re: 10/11 September
Post by FORGE1 »
Replaced the gearbox in the bighorn :) this would have to be the best gearbox i have put in it so all in all happy with it.
SP450andLE
Re: 10/11 September
That actually sounds like a good idea. :shock:
But I will want to eat it all the time. I used to live off liquorice allsorts whenever I used to stay at my Nana's place :lol:
Maybe I could paint the middle strip bit black, and pimk above, and orange below? (side strip can be seen in the following photo)
SP450andLE
Re: 10/11 September
Blergh, sorry about the big pic, I had resized it, but it came out big anyway :roll:
SV1K
Site Admin
Re: 10/11 September
Post by SV1K »
Just got back from a epic day in the Firewood loop (Akatarawa forest), headed in at 10am this morning and got the the start of the track at 10:45 am, managed to get out the other end at 8:10 pm! only 4 trucks, three with winches (2 that worked after about 40 minutes after we got in there - cooked motor) A few trees were down but nothing to major.
When we got out we were faced with a rather big tree that we couldn't cut through, so it was back the way we came in... only took about 30 minutes to get back out...
Fantastic trip and thanks to Lyn, Ashleigh, Hayley, Mark, Willie, Rob and Graham for a fantastic day!
Reece
Beer_Cruiser
Re: 10/11 September
Post by Beer_Cruiser »
suzuki1k wrote:Just got back from a epic day in the Firewood loop (Akatarawa forest), headed in at 10am this morning and got the the start of the track at 10:45 am, managed to get out the other end at 8:10 pm! only 4 trucks, three with winches (2 that worked after about 40 minutes after we got in there - cooked motor) A few trees were down but nothing to major.
Reece
Photos or it never happened!!!
SV1K
Site Admin
Re: 10/11 September
Post by SV1K »
Beer_Cruiser wrote:Photos or it never happened!!!
Photo's were the last thing on our minds and I don't think anyone had a camera... but you are more than welcome to come and look at the trucks and their condition.... :lol: :lol: :lol: :lol:
Dr_PC
Re: 10/11 September
Post by Dr_PC »
Good days play yesterday in Woodhill, Heap of vehicles in there, after leaving the carpark saw the recovery patrol twice, Thanks christ for that 1st time was GIVEN 2 8.8 bolts and nylocks to hold my drivesharft on as 2 bolts were gone and the other 2 were ready to fall off. 2nd time was to be told go down there and take the 2nd turn on the right - New tracks with no signs the most fun all day. Thanks guys and then at the end of the day saw some of our other club guys otherwise didn't know anyone else was in there.
Many thanks to the man from Shore who GAVE me spare bolts would not accept an payment for them, TOP MAN.
Dr_PC
Re: 10/11 September
Post by Dr_PC »
rokhound wrote:The other way to put that is "Most sport requires one ball, Real sports require 2!" :lol:
Do you walk funny when you play snooker :lol:
