The motor on my 8274 is a loaner. I'm after a new one. Can anyone help me with info regarding how much a replacement one might cost or what would be the best replacement? Someone was talking about the Gigglepin dual motor and gearbox setup but to me, I'm happy with the standard motor.
Cheers. Pete.
(wish the 'Notify me when a reply is posted' was working)
Fully Equiped are the Warn NZ agent. You want the 6hp motor off their XP9000 winch. Feed it with 95mm cable and you'll never look back.
If you decide you do want to go twin motor, let me know I can do you one for prob less than half the Giggle pin one. (Race proven)
Hi Pete I got a 7.8Hp replacement motor for my 8274 from G Guy motors in welington you can get the same motor from 4WD bits for $909.69 they are not cheap but they are very good cheers Brent
probie wrote:Hi Pete I got a 7.8Hp replacement motor for my 8274 from G Guy motors in welington you can get the same motor from 4WD bits for $909.69 they are not cheap but they are very good cheers Brent
meatc wrote:Fully Equiped are the Warn NZ agent. You want the 6hp motor off their XP9000 winch. Feed it with 95mm cable and you'll never look back.
Cheers for the offer. Out of interest what's the Gigglepin gearbox n motors worth as a package?
Giggle pin housing will set you back a little over $2K no motors (or the last one that I know of was). The add a couple of the warn XP motors, solinoids, wiring and you are well over $4k.
For a replacement motor, the warn XP are faster and seem to have a bit more go than the Superwinch 7.8s mentioned above. Nothing worng with the 7.8s, they will pull all day, just not quite as quick.
petefj40 wrote: Cheers for the offer. Out of interest what's the Gigglepin gearbox n motors worth as a package?
Got ours to our door for just over $2000, 6hp motor was $760 inc GST. Great thing is you can increase gear ratios with the gigglepin, standard, 13%, 25%, 40%, 50% and 60% increase of you choice. They are very well made, very happy with ours.
