Took the 80 to get a wof this morning and it blew the front right brake hose on the rolling road. Subsequently it failed. Rang around to get a replacement and picked one up from B.N.T. Got it back home to the sticks, tried to fit it but the bastard won't thread on to the steel brake line. Thread appears to be the same, internal diameter same. The joker who served me had a look at the old one, we both thought it was the same. Cruiser now sitting in driveway with no brakes and spare brake line that wont fit. Are there more than one type of union for the 80 series?
Any ideas?
HDJ81 Blown brake hose
- cornfarmer
Nothings a problem if you don't give a f#ck.
Re: HDJ81 Blown brake hose
You might find the tip of the fitting on the brake pipe / line has flared out and wont fit in the new brake line.
Have had it happen to me.
Tweak with a file.
Tweak with a file.
kbushnz wrote:You might find the tip of the fitting on the brake pipe / line has flared out and wont fit in the new brake line.
Tweak with a file.
What he said.. toyota stuff ALL bolts together well.. and I have had this happen to me.. Just when it was bolted up the flare has just spread a little more.. file is your freind..
- cornfarmer
Cheers guys. Will attempt the neccesary mods.
- cornfarmer
Filed,fitted, and wof'd.
Cheers guys.
Cheers guys.
- cornfarmer
Cheers guys.
Cheers guys.
