I'm not buying another soldering iron as my Grandfathers is available down south which I'm going to grab on the 8th but need to do these brushes before then.
Big Heavy Soldering Iron Needed Wellington
- mike
- Last minute Mike
The second soldering iron i bought to do electrics has just given up the ghost (doesnt even heat average wires anymore )
Anyone have a big heavy soldering iron I can borrow for tomorrow or wednesday please? I'm going to attempt to solder some brushes into my winch motor on the house (boat) and these are thick buggers.
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
Re: Big Heavy Soldering Iron Needed Wellington
how big is big mike .i have a range of soldering irons
You should check and see if your local Repco has the $10 small pencil gas torch, brilliant for doing large soldering jobs, especially winch power cable and the likes
- mike
- Last minute Mike
sig wrote:how big is big mike .i have a range of soldering irons
Not sure, big enough to solder some brush wire together which is about 3mm diameter. My one just won't even look at that
1994 Toyota Surf
1994 Toyota Surf
