Help needed urgently - West Auckland
Posted: Sat Oct 01, 2011 1:37 pm
by Filthy4x4
Hey guys,
Urgently need to get my truck running.
Its a 2LT surf, manual.
Just put a new alternator in it and replaced the belts, now it wont starts its like it has a flat battery so we hooked it up to another car and left it running for about15mins and its still not turning over any better.
The battery gauge says it has enough to start it but as soon as you try turn it over the battery level drops to 0 even with another running car onto it.
Any ideas? or anyone that can come and help me asap? Will supply beers for time
Im supposed to have been at a mates 21st like 3 hours ago
Caleb
0211253921
Re: Help needed urgently - West Auckland
Posted: Sat Oct 01, 2011 2:43 pm
by mud_slinger
checked ya earths?
Posted: Sat Oct 01, 2011 2:48 pm
by andy3542
you should've called me this morning and i could've come help, instead i went to see the landy and achieved nothing.
power dropping away like that is probably a dodgy earth or not enough of an earth, just had the same happen to my flat mates nissan.
Posted: Sat Oct 01, 2011 3:06 pm
by Filthy4x4
Yea I have checked all earths. I never touched any when taking it apart as the alternator mount is earthed. Everything is back on where it came from.
I give up for today, will try again tomorrow
Posted: Sat Oct 01, 2011 5:43 pm
by jeremy
Have you tried another battery - might have a dead cell?
Posted: Sat Oct 01, 2011 5:58 pm
by Sadam_Husain
uwshho wrote:Yea I have checked all earths.
when you say you checked the earths did you take them all off and give them a clean up and put them back or did you just visually look at them, did you check the positive HT lead as well?
Posted: Sat Oct 01, 2011 6:12 pm
by Lynx
jeremy wrote:Have you tried another battery - might have a dead cell?
Agreed, try another battery, or get it load tested.
Cheers Daniel
Posted: Sat Oct 01, 2011 6:29 pm
by KIWI_TERRANO
most likely when the last alternator started to die it would have started to kill the battery and now it f like my surf did so most likely get new or try another
Posted: Sat Oct 01, 2011 6:40 pm
by sibainmud
I have an electronic tester here and the usual plethora of test equipment
You know where i live
Posted: Sun Oct 02, 2011 1:38 pm
by Filthy4x4
Sadam_Husain wrote:uwshho wrote:Yea I have checked all earths.
I cleaned the earths with brake cleaner, on starter, batt and alternator.
I have borrowed some gear off Simon and have done a battery test, its coming up with 12.37v then when tested says Bad & replace so I grabbed the battery out of flatmates honda (330cca not sure if this is enough or not) it turned over a little better but then still did the same thing.
The volt meter also dropped when under load. I have tested the starter motor also and its reading 12.37v there also.
Im unsure whether to go grab a new battery or not yet if it is something else causing the problem.
Iv run out of ideas
Posted: Sun Oct 02, 2011 2:10 pm
by kbushnz
uwshho wrote: so I grabbed the battery out of flatmates honda (330cca not sure if this is enough or not) it turned over a little better but then still did the same thing.
That wont be enough for the Diesel....Need something in the 600 plus.
Posted: Sun Oct 02, 2011 2:27 pm
by Filthy4x4
kbushnz wrote:uwshho wrote: so I grabbed the battery out of flatmates honda (330cca not sure if this is enough or not) it turned over a little better but then still did the same thing.
I just went out and got a 600cca batt. It turned over and did the same thing again, then the next time it cranked a bit faster was just about to give up on it but gave it one last try and it started first pop
Now theres a lovely screeching sound (sounds the same as a shot release bearing does) coming from the alternator or something around that area.
I cant figure out what it is or exactly where its coming from so wont be driving it til I can sort that out
Posted: Sun Oct 02, 2011 4:34 pm
by kbushnz
Sounds like the belts are slipping.....
You will need to remove. clean / scotchbrite your connections....Especially the earth.
Both on the cables and where they bolt to.....
Earth leads to engine block too....As that's where the starter gets its earth.....
I had similar issues with dirty corroded battery terminals...
They would start great, then the next just click click click.
Posted: Sun Oct 02, 2011 4:36 pm
by mudslut
Are the terminals on the new alternator and the old one the same configeration(+ & - ),if they are the wrong way round the alternator will run on full power thinkin the battery is flat,that will cause screechin through belt slip
Posted: Sun Oct 02, 2011 4:44 pm
by Filthy4x4
kbushnz wrote:Sounds like the belts are slipping.....
I thought it could be the belts slipping but its sounds like a metallic kind of sound like something thats supposed to be spinning isnt spinning properly or its touching something else metal.
It starts first time everytime now its just this noise I need to sort out
It never ends
Posted: Sun Oct 02, 2011 4:51 pm
by Filthy4x4
mudslut wrote:Are the terminals on the new alternator and the old one the same configeration(+ & - ),if they are the wrong way round the alternator will run on full power thinkin the battery is flat,that will cause screechin through belt slip
Im not too sure dude, iv never had to touch an alternator before this
The plug on the new one was different so i took the plug off the old one and swapped the bit that has the contacts on it over. So im not sure if thats changed anything or not, the belts are done up fairly tight maybe just over 5mm play in each one.
Theres definitely something not right with the wiring as a couple of the dash lights are staying on when its running (batt light included).
Me and electricity have never been good friends, I hate trying to fix things that are invisible
I may have to get someone to look at it, this sort of thing is out of my league
Posted: Sun Oct 02, 2011 5:07 pm
by Lynx
Can you see sparks in the alt?
Posted: Sun Oct 02, 2011 5:29 pm
by Filthy4x4
Lynx wrote:Can you see sparks in the alt?
Cant say I was looking for them but I didnt see any when I was looking at it.
Posted: Sun Oct 02, 2011 5:38 pm
by mudslut
uwshho wrote:mudslut wrote:Are the terminals on the new alternator and the old one the same configeration(+ & - ),if they are the wrong way round the alternator will run on full power thinkin the battery is flat,that will cause screechin through belt slip
Id say the wires are around the wrong way,switch them around and give that a go
Posted: Sun Oct 02, 2011 5:51 pm
by Filthy4x4
I thought it could only go on one way
im pretty sure I put the plug unit on the say way as the one I took off. It may not be earthed properly or something as it was slightly different.
Should I try tightening the belts as well? How tight is too tight?
Posted: Sun Oct 02, 2011 6:02 pm
by mudslut
uwshho wrote:I thought it could only go on one way
If the plug was different there is a bloody good chance that the wires could be different too
Posted: Sun Oct 02, 2011 6:10 pm
by Filthy4x4
Yea thats true. The plug wasnt far off it was just slightly smaller but everything else looked the same.
Posted: Thu Oct 06, 2011 4:12 pm
by Filthy4x4
Right problem is now solved,
HUGE thanks to Simon (sibainmud) for pulling apart the alternator and diagnosing the problem as a rooted front bearing then replacing for me
Posted: Thu Oct 06, 2011 8:01 pm
by sibainmud
So it works all good then?
The bearing was the easy part. I was more worried about the regulator connections
You're most welcome.
We won't mention the Charade wheel bearings either
Posted: Thu Oct 06, 2011 8:52 pm
by Filthy4x4
sibainmud wrote:So it works all good then?
Oh yea thanks for the charade bearing was so damn nice to drive to work in silence this morning
I had to keep checking the car was still running
Will have to figure out further what to do with these reg connections, I think its best if i stay clear from it
