Got it, it was filthy inside, so much dust and it has been run out of water. SO hot the top tank on the radiator was melted. Some pics.
Started yesterday morning, I pulled the engine out...
The 2.8's and 3.5's have a pull clutch which is a sod of a thing to get out, there is a pin with a bolt in it inside the bellhousing. I have two special tools for the job, I made one up when I took the clutch out of the 3.5 a few years ago. this time the pin wouldn't slide out so needed tool number two.
bellhousing showing pull clutch
To get the top bellhousing bolts I gave big black a body lift
4 lumps of 4x2 did the job
Stripped interior (found some money!!!)
Vacuumed it
Pulled windows out and waterblasted them
Waterblasted all the pastics inside the vehicle also then started on the carpets.
Got most of the dust and dog hair out I think, I sure hope so anyway. Started reassebling, as much as I can until carpets dry.
Pulled turbo off manifold ready to drill for a exhaust temp gauge.
Cleaned the inlet manifold and rocker cover to within an inch of its life, this thing was rather full of gunk.
Thats it for now.
Glen
