60 series rear diff 4.1 ratio
Hey all After another diff for my truck, My one at the mo seems to have a very loud whine is and getting pretty anoying!.
Real bummer because it is the cable locking one.
But for now any replacement diff will do.
Thought about swapping the front to the back but thats a big job and not up to it at the moment.
Fully float axle so should be easy to swap over.
Aaron.
Aaron.
Re: 60 series rear diff 4.1 ratio
if its a 4.1 toad10's got a cheap one on TM for $75, I've brought stuff off him before
Sadam_Husain wrote:if its a 4.1 toad10's got a cheap one on TM for $75, I've brought stuff off him before
Sweet good to know! Have got it saved. Cheers.
- MNC
I've got a couple lying around the place.
Let me know if you dont get that one on trademe. I'd happily swap one for your one
Cool MNC will let you know if i dont get it.
Found another one on trademe which is local so might pickup that one.
Heh as much as i would just swap it, It will be re used later on ( rebuild bla bla etc) for now itl be a shelf ornament
It's a factory cable locker, yes? Spend a little more extra an get new bearings put in the diff head
Didn't barbie drive a jeep??
some of the housings are different if they have a factory fitted locker and a standard diff wont fit.I know the e lockers are like this but not sure about the cable operated ones.
Fakey wrote:It's a factory cable locker, yes? Spend a little more extra an get new bearings put in the diff head
:O A mate reckons a waste of time redoing all the bearings etc as the teeth etc could be worn out, But to be honest that was my initial plan.
Basicly i can drive along coast slighty and nearly have no noise, accelerate and it comes back. Chuck the clutch in and it reduces the sounds heaps but can still slightly hear it.
Overall would rather rebuild it etc.
sprey wrote:Fakey wrote:It's a factory cable locker, yes? Spend a little more extra an get new bearings put in the diff head
Wait so if you put the clutch in the noise pretty much goes away? I'd be looking at the input bearings in the gearbox, the 60 series box in my truck made loads of noise with worn input bearings
Give your mate a slap next time ya see him
Fakey wrote:Wait so if you put the clutch in the noise pretty much goes away? I'd be looking at the input bearings in the gearbox, the 60 series box in my truck made loads of noise with worn input bearings
Give your mate a slap next time ya see himeven off the gears were worn it's easy enough to get good 2nd hand or new ones fitted when it's apart getting bearings done
Will do :p.
Ill have to take her for a run and double check. But yeah clutch in or in neutral it seemed to disppear quite alot, But i can still hear a noise in the diff but nothing really bad i think :S. Will take her for a run 2mrw and report back
Gearbox related stuff sounds $$
Cheers man really appreciate this Saves me doing work that i dont need to do.
- ClassicCruiserSpares
- Sausage Shack
I just put all new bearings a seals in a customers 60 series 5 speed for less than $500
ClassicCruiserSpares wrote:I just put all new bearings a seals in a customers 60 series 5 speed for less than $500
Hmm thats pretty good! I guess the more $ part is removing the gearbox etc.
- Sausage Shack
sprey wrote:ClassicCruiserSpares wrote:I just put all new bearings a seals in a customers 60 series 5 speed for less than $500
Yea the labour cost of removing, repairing and replacing Is more than the $500 for parts.
ClassicCruiserSpares wrote:sprey wrote:ClassicCruiserSpares wrote:I just put all new bearings a seals in a customers 60 series 5 speed for less than $500
Gotcha just as i thought :p. Gonna pop down to a mechanics and have a chat. Of course if they do the gbox, Might as well do a few other things as preventative maintenace :p See how we go cheers for the info.
- MNC
sprey wrote:Fully float axle so should be easy to swap over.
Can be hard determining where the noise is coming from when you are driving.
One option could be to remove the rear drive shaft and axles and take it for a drive in 4wd (actually front wheel drive)
If its still noisy then its not the rear diff...
Just a thought if you wanted to rule some things out before paying labour to have it fixed.
- Bush Crasher
my cable locker has lost the side gear spline
lost drive just made horrible noise for a bit of triva the open diffs side gears are the same as the cable lockers but the berings are different
also mine had same noise and crown wheel and pinion need replacing
so need set of 4.1 in chch
- Bush Crasher
fisho wrote:some of the housings are different if they have a factory fitted locker and a standard diff wont fit.I know the e lockers are like this but not sure about the cable operated ones.
wish i had read this before i went and tried to fit one
the normal crown and pinion are way different as well the locking pinion one is much larger so that doesnt work either
