Sj413 parts to sj410 ?
For all Suzuki related topics
Nz Zuki
Post by Nz Zuki »
Howsit guys just want to pick your guys brains. i have a sj410 chassis, transfercase and diffs,which has a 413 body on it. but have recently brought two sj413s for parts etc. do the sj413 diffs fit straight under the sj410? or do i have to modify spring perches and stuff? also whats the diff ratios and which is better? also + and - ? of the both diffs and stuff or whats good to change over and whats not? cheers guys
suzookyman
Re: Sj413 parts to sj410 ?
Post by suzookyman »
pm sent
Nz Zuki
Post by Nz Zuki »
Sorry mate. He changed it for me. i was speaking to him on the phone as he changed it, because we had organised it and i had viewed the zuk the day before. were you after parts?
UBZ
Post by UBZ »
:D :D :D all's fun and war on tardme . :D :D :D
413 diffs will bolt straight under the 410. drive shalft flanges are different though. and diff ratios are different.
Nz Zuki
Post by Nz Zuki »
UBZ wrote: all's fun and war on tardme .
is the diff ratio change a good or a bad thing? will it make my gears lower or higher? the other thing is can i use the 413 driveshafts and just change around the fittings on the 410 transfer box to 413 ones? heaps of things to consider??
lilpigzuk
Tiger Balm
Post by lilpigzuk »
Have you tried searching at all?
Been covered a heap of times here and god knows how many times overseas...
http://www.offroadexpress.co.nz/Forums/ ... d%5B%5D=23
deanviall
Newbie
Newbie
Post by deanviall »
the biggest issue is Flanges.
In a perfect world you'd use 413 diffs with 413 driveshafts and 413 transfer case. OR all 410 stuff.
The flanges can be tricky to swap, and you can also swap yokes from the driveshaft ends but then you also have issues with the u-joints that need to be solved as well.
The 410 diff housings are smaller so you get better ground clearance, and you'll have lower ratios with 410 diffs. They are skinnier too so U-Bolts might be proud.
I understand you can swap 413 axles in the front which are stronger than 410.
I think theres also a rear brake hose mount difference.
Bottom line, 410 diffs are better because of the ratio and ground clearance.
Return to “Suzuki”
