I did a bit of prep work before hand like sourcing the shocks and the springs as well as tidying up the axle, cutting the radius arm mounts off the axle and tidying up the chassis mounts for the panhard rod and the spring and shock towers.
All that's left to really sort out is the wide axle swap and free wheeling hubs. I think i have the wide axle swap sorted:
you mill 1.5mm off the outside of the mounting posts of the caliper and drill the thread out of the knuckle. You can then either tap the caliper or put a bolt straight through. You then just need to drill the new holes in the original prado rotor. Please correct me if i am wrong.
The next bit is the free wheeling hubs. I know due to spline counts you can't use the surf free wheeling hubs. is there any other way of doing it like using hilux ones?
When i get some photos of the progress i will update the thread.
Sam
