newbie with what is that dam button question?!
u13turbo
Re: newbie with what is that dam button question?!
Post by u13turbo »
henrysj wrote:Hi guys,
Just picked myself up a 94 terrano 2.7 diesel manual truck a couple of days ago. Only done a short little road trip from buying it up in auckland back to home in Queenstown but pretty chuffed so far, had heaps more grunt than was expecting and seems to go pretty smoothly.
The whole way down though I was doing my nut in trying to work out what the button to the left of the steering wheel does. Its a pull out button that has a picture of a transmission on it (think thats what it is anyways). If it wasnt a diesel would have guessed it was the choke. 4hrs searching on the internet and i'm still no closer to finding out what it is.
Will some one please put me out my misery and tell me what the dam it is?!
Thanks heaps
Henry
If its the one im thinking of, its like a hand throttle, pull it out and you'll see.
monstr
Post by monstr »
Try Turning it ,Revs should increase.
badnuz
Post by badnuz »
have you done it yet???
mud_slinger
Post by mud_slinger »
its when you are lazy and in 4wd you can take ya foot off accelerator and use the idle up :wink:
needs more curry
0272593533
vinceparts
Post by vinceparts »
itd be usefull if you had a tipper on your terrano :lol: :lol: :lol: :lol: :shock: :shock:
niblik
Post by niblik »
hand throttles are handy to up the rev's when doin winching or bimblin along uneven terrain.. also for warmin up ya rig..
i lurves mine..
pruggerdore
Post by pruggerdore »
also been use full when stuck so you can have wheels spinning slightly and get out and push haha
sibainmud
Post by sibainmud »
I have used mine for cruise control on the motorway, doesn't disengage when you hit the brake though :? :lol: :lol:
Hand throttle, used for warm up or charging flat battery or uneven ground much smother than the foot.
Pico42
Post by Pico42 »
Our old man used it to set the speed on the farm truck then let us kids steer while he was on the trailer when feeding out.
kaukapakapa
Post by kaukapakapa »
If it doesnt work dont worry as mine didn't. they are sometimes disconnected. It is supposed to be a hand throttle. It is a pull and twist to lock type.
juz
Post by juz »
Ull want it in Qtwn in winter, go start it up in the morning,crank the idle up a bit aswell as the heater and demister.Go inside finish ya Coffee and toast, go back outside, revin its tits off but cosy warm and frost free windows. :D
mercutio
Post by mercutio »
it is a hand throttle use it while the engine is warming up so the engine runs smoother and when it is warm drop the revs back down to normal again usually only need to increase the revs by less than 100 rpm to get rid of the shudder
my 4wd is not a truck
muddy
Post by muddy »
Also real handy on steep hill starts when the hand-brake won't hold. Keep ya right foot on the brake and wind up the revs a little so it doesn't stall when you let the clutch in....
