wtb disco1 r/h front door handle and lock
Posted: Tue Oct 18, 2011 8:47 pm
by pajero1983
went to unlock my disco this morning and it felt funny and would not unlock
just got the door panel off witch is not fun when u cant open the door lol to discover the plastic ring that holdes the locking rod to the back of the key barrel has broken!! does anyone have one or a complete unit i could buy from them? i dont seem to be having much luck this month with things breaking!!!
cheers guys.
Re: wtb disco1 r/h front door handle and lock
Posted: Tue Oct 18, 2011 9:37 pm
by Mudde1
looks like this is a common problem. i have exactly the same problem. you can buy the part from land-rover spares, he has two on stock. $85 plus GST. Land-rover NZ also has them, $110.00 plus GST. i am thinking about machining one out of alloy, but i don't have the bit that has broken off, so don't know what the unbroken part looks like.
Posted: Wed Oct 19, 2011 7:43 pm
by pajero1983
Mudde1 wrote:looks like this is a common problem. i have exactly the same problem. you can buy the part from land-rover spares, he has two on stock. $85 plus GST. Land-rover NZ also has them, $110.00 plus GST. i am thinking about machining one out of alloy, but i don't have the bit that has broken off, so don't know what the unbroken part looks like.
Sweet mine is split and when u apply pressure by turning the key it just opens up!! so is the $85.00 a complete unit door handle barrel and key? or just the plastic part?
Posted: Sun Oct 23, 2011 7:27 pm
by Mudde1
no just the plastic part. i wondered if there was a matching part in the left front door that i could swap over, wouldn't matter so much if the central locking didn't work from the left side.
Posted: Sun Oct 23, 2011 7:48 pm
by Overkill
Does the inside lock go back down once you unlock the door (by key or remote) and then it is as if it locks itself again, you can't open by the door handle unless you turn and hold pressure by the key or hold up the inside lock?
Easy fix if it is, little springs inside the locking mechanism.....I got mine off a place on ebay for cheap.....I will hunt them down for you if that's your fault....
Posted: Mon Oct 24, 2011 1:10 pm
by pajero1983
Mudde1 wrote:no just the plastic part. i wondered if there was a matching part in the left front door that i could swap over, wouldn't matter so much if the central locking didn't work from the left side.
I was thinking the same thing $80.00 for the little plastic cam what a joke :lol: as long as it can be flipped over we should be sweet
Posted: Mon Oct 24, 2011 1:13 pm
by pajero1983
Overkill wrote:Does the inside lock go back down once you unlock the door (by key or remote) and then it is as if it locks itself again, you can't open by the door handle unless you turn and hold pressure by the key or hold up the inside lock?
No it doesnt do that its the little plastic cam cracked on the end of the key barrel they want $80.00 for it lol. i think a mates one does what your talking about he has a alarm with keyless entry and somtimes that goes mental.
Posted: Tue Oct 25, 2011 8:33 am
by Bubba
You could try and find a Morris Mariner, they have the same door locks :oops:
Might be a cheaper option
Posted: Tue Oct 25, 2011 11:28 am
by ice4x4
Try getting one from the UK. It'l probably cost you 20 bucks plus 10 bucks postage.
Worth a try anyway.... :wink:
Posted: Tue Oct 25, 2011 1:04 pm
by Overkill
pajero1983 wrote:No it doesnt do that its the little plastic cam cracked on the end of the key barrel they want $80.00 for it lol. i think a mates one does what your talking about he has a alarm with keyless entry and somtimes that goes mental.
Gotcha, a friend of mine is wrecking a Disco here in Pram with all the goodies still on it. PM me your details and i'll see what I can do :wink:
