Page 1 of 2
Oct 22 - 23 2011
Posted: Thu Oct 20, 2011 7:36 pm
by Dr_PC
My Weekend starts NOW, Buggy is finished and loaded, we leave at 9.00am tomorrow morning for Inglewood. Why do we always wait till the last night to get things finished
Re: Oct 22 - 23 2011
Posted: Sat Oct 22, 2011 5:27 pm
by lincooln
Well today I bought a new fire extinguisher to replace my empty one, then decided to fix the back door on the zuk. It now locks and can be opened form the out side. Bloody amazing
Also just heard that the norwest guys and some naki guys that went up to Thompsons today are now down to 3 trucks only :shock: . Not sure how many have gone out but it sounded like a good effort. They are meant to be doing more tracks tomorrow but who knows now. :lol:
Shame I couldn't make it down though.
Posted: Sat Oct 22, 2011 6:26 pm
by new2zukes
straightened my high lift jack after bending it at mwc
Posted: Sat Oct 22, 2011 7:57 pm
by suzookyman
new2zukes wrote:straightened my high lift jack after bending it at mwc
WTF :shock: Howd ya do that?
Posted: Sat Oct 22, 2011 8:04 pm
by andysh
I'll be heading up to Woodhill on Sunday morning for some fun. :D Hopefully not to much panel damage... bit hard with a whale.
Posted: Sat Oct 22, 2011 8:18 pm
by worzel
spent all day sat rewiring the whale after rev lights shorted out and all melted together they are not protected by a fuse so burnt all the loom out from from the rear left light right upto the front bulkhead was a pain in the ass but managed to get it all done and rev lights are now fused
Posted: Sat Oct 22, 2011 8:31 pm
by kbushnz
Almost finished a spare PTO drive shaft. Played with my boys MR2....Needs a good tune up...
Posted: Sun Oct 23, 2011 7:29 am
by Mudhog
The Mudhog started to run rough 100M from home and just got back before it stopped and wouldn't run at all :x
Would turn over, but had no spark!!!
Spent Thursday afternoon and yesterday trying to get it sorted :roll:
I started making some phone calls and spoke to a few different guy's to try and sort it out and get an idea on what it might be :?:
After spending 3 hours checking wiring and cleaning connection, we found it was a broken socket pin in the black amplifier box on the side of the dizzy, I only found it after Shaun pulled the plug off and said was there meant to be two or three pins in there?
After cleaning out more Woodhill Mud :lol: and having a check in the Haynes bible I could see that one of the pins was snapped off!!
I picked up a new one and started the job of replacing it.
First thing was that the dizzy needed to come out to get to the screws holding in the black box..Shit first time for everything I guess :!:
I spent a fair bit of time cleaning around the dizzy and then marking everything as a few people had said if you get the dizzy back in out of place it's a bitch to get sorted :roll:
Marked the dizzy cap, leads, dizzy body to the block and pulled it out... Shit here goes nothing.
While I had the dizzy out I decided to try and waterproof it. I set about doing this by filling the two small holes on the bottom of the dizzy body (these let steam and water in) and drilling and tapping two new ones and fitting grease nipples that I had drilled out with a 3mm drill to just below the clips that hold the dizzy cap on. I had been told that you need to have air flow to help keep condensation from building up under the dizzy cap.
Now it's time to refit the dizzy...Here goes... lined up all the marks... first time they didn't all line up, pull it back out and try again, this time everything lined up :D
Now to try and start the truck.....Turned the key....and...it fired up as soon as the key was turned and sounded great :D
I finished fitting the air tube from the new grease nipples, one to the airbox to create suction and the other to in side the cab to supply clean dry air.
Now all I need to do is try it in some water!!! :lol:
Cheers Brett
Posted: Sun Oct 23, 2011 7:56 am
by ice4x4
Glad you got it sorted!
Posted: Sun Oct 23, 2011 7:59 am
by Mudhog
Me too!!!
Posted: Sun Oct 23, 2011 10:35 am
by turoa
Mudhog wrote:Non-novel version ... Replaced dizzy
Posted: Mon Oct 24, 2011 7:52 am
by sibainmud
lincooln wrote:Also just heard that the norwest guys and some naki guys that went up to Thompsons today are now down to 3 trucks only :shock: . Not sure how many have gone out but it sounded like a good effort. They are meant to be doing more tracks tomorrow but who knows now. :lol:
Here,s the full story with some illustrations :mrgreen:
We had 8 trucks to do Thompsons.
Some trucks had problems before we even got on the track (hibrid zuks :roll: )
Easy, fun drive up Te Aroha side. Ian even got his Whale up to the summit.
Had an awesome play in all the areas on the way down too.
Most of the guys had other places to go or went home after Thompsons.
Graeme sat on the rev limiter too long and a death rattle was the end result. So back at camp some rush repairs were required, with the verdict of terminal being pronounced.
The Vatara, had a water pump replaced and the clutch cable jury rigged with Num 8 fencing wire.
So that left us with only three trucks for Maratoto.
Paid the fee and went to the hut and looked at the recent work done to the track. Looks good :P
(notice the only truck with out it's bonnet up?)
Got to the hut, the white zuk with hilux diffs had stripped and pulled out 3 of the 4 bolts on the left hand steering arm, so it was jury rigged to get back out. This meant only 2 trucks to do the loop. So it was decided to just poke our noses up the loop. Drove about a tenth of it and turned around.
Travelled back home to cook a BBQ for over 30 guests coming to watch the game.
More pics and film will surface for sure.
Posted: Mon Oct 24, 2011 9:55 am
by zukmeista
Washed my Samurai :D Shows up all the dents and scratches :cry:
Posted: Mon Oct 24, 2011 11:29 am
by FORGE1
Spent part of yesterday fitting my spare guards to the front of the bighorn so I could do some cutting and hammering to them so I could then start to use it haha as its been sitting in the driveway not moving because I couldnt turn. End result is I can now turn corners without ripping everything up.
Was mean to head to hellensville to get another bighorn this weekend but there was a issue with the garage and could get it out so thats next weekends trip now :)
Posted: Mon Oct 24, 2011 12:11 pm
by u13turbo
Glad to see the mighty terrano was one of the last standing!
Posted: Mon Oct 24, 2011 12:19 pm
by rotordogg
Dr_PC wrote:...Why do we always wait till the last night to get things finished
Last night?? Had truck in at dyno guy trying to work out problem with engine after transplant (ended up being sparkplugs) the morning of scrutineering! lol...
Stoped at Dan Cowpers workshop on way to scrutineering to change plugs, modify front lower arm mounts for new arms, make new brackets for brake hoses etc...
Got there in the end though...
Was a good weekend away!
Posted: Mon Oct 24, 2011 1:33 pm
by coxsy
refitted battery leads, started the saf up after more than 4weeks, running sweet , well sort of haven't heard a nissan 4.2 for the the same 4 weeks, seems ok :D
Posted: Mon Oct 24, 2011 2:20 pm
by monstr
Got To Love the good old reliable Nissan aye Simon :)
Posted: Mon Oct 24, 2011 4:13 pm
by safaripete
got my suzuki resprung and moved so i can clean the workspace :oops:
Posted: Mon Oct 24, 2011 4:38 pm
by mud_slinger
completely stripped and cleaned up front hubs, new wheel bearing kits, seals,marine grease and sealed the lockable hubs with sealant. got the leftside put on and sanded the brake pads to get rid of rust and mud, cleaned up left calliper regreased with rubber grease. Got the mrs out in the truck wiring in the head unit and prs radio back up. i even brought a aerial and cabling for it. halfway there
Posted: Mon Oct 24, 2011 4:52 pm
by SP450andLE
Accelerator pump diaphragm didn't turn up, so couldn't fix that.
So I pulled the engine out of my Mini instead. Now to strip all the paint/crap etc from the engine bay... :roll: :lol:
Posted: Mon Oct 24, 2011 5:33 pm
by sibainmud
monstr wrote:Got To Love the good old reliable Nissan aye Simon :)
Yeah, I think it came out tops. Did more track k's, more winch metres than any other and drove the 300 odd K down there and back :D
This is all the video I have.
Enjoy :mrgreen:
Posted: Mon Oct 24, 2011 5:49 pm
by kbushnz
Cool Vid Simon.......Keep em comming
Posted: Mon Oct 24, 2011 7:06 pm
by chrome
got the vitual lift sorted today :D
done a bunch of rusty repairs and played round with the carby
Posted: Mon Oct 24, 2011 8:15 pm
by Drurban
Well after Thompson's, and gave the truck a clean, I went and moved my antenna from the front guard to the the back of the truck this way it is out of harms way so it wont get knocked by those damn trees.
The antenna does not look straight up and down I still have to rework the mount but this is were it is going to go.
Cheers.
Posted: Mon Oct 24, 2011 8:24 pm
by Drurban
Posted: Mon Oct 24, 2011 8:30 pm
by SP450andLE
Ahh, I can see both lots of photos :wink:
Posted: Mon Oct 24, 2011 8:32 pm
by UBZ
chrome wrote:got the vitual lift sorted today :D
looking good , but are you going to finish the virtual lift?
Posted: Mon Oct 24, 2011 8:36 pm
by niblik
went to reefton with jason and kbjj and also some other top chaps.. had a ball pedallin around slab hut creek and doing the chasm. camped out the whole time with perfect weather. took my 15year old daughter and it was her first time wheelin like that.. she lurved it! heh..
parked in the chasm.. only got 6 photos as she was ridin navi every time i was movin, lol..
thanks to the guys and girls i went with. will be goin back again..
Posted: Mon Oct 24, 2011 9:04 pm
by chrome
thats it all welded :mrgreen:
