Ive got a Lincoln 180c which is the best 180 amp welder I've ever used. But they are abit over $1500. A mate of mine has a Magmate 180 and it seems to be a good welder and they are backed by Boc. I think he paid $1180 brand spankers for it. Try and buy one which takes a 15kg roll of wire (Mine doesnt
) 5kg = $50ish, 15kg = $40ish!!!
Duty cycles will be worked out in %. Best way to figure it out is 100% duty = 10mins.
This isnt quite correct. If a welder is 100% at 140A then it will go all day at 140A or under without a cooling down period. The percentage is worked out by the hour. So a welder with a duty cycle of 75% at full noise will go for 45mins in an hour then need 15mins cool down.
The other thing is Lincoln, Magmate etc are 15amp input and you really need a minimum of 2.5mm wire going to your plug.
Also dont be temped to buy a machine which has other shit on it like Plasma cutters or Tig set ups. They break down and then you aint doing no welding at all
If you are tempted by a multi set up then buy a dedicated power pack with a seperate wire feeder.
