80 series Front Diff Housing
- ClassicCruiserSpares
- Sausage Shack
Im trying to track down an 80 series landcruiser front diff housing it is the factory diff lock type, Not sure if the non diff lock type are the same? If any one has one they want to part with or know of any wreckers that mite have one in stock? any help would be much appreciated.
- Sausage Shack
Re: 80 series Front Diff Housing
Bump anybody know of anything?
I know that commercial spares in Takanini Auckland normally has some in stock not sure if they will have a locker one. they are not cheap from them, think almost $400 for bare housing no swivels or anything. Can help you move it to mainfrieght if it comes to that.
Good luck
Mike
Good luck
Mike
You can fit a locker head into a non locker housing by removing the studs that hold the head and replacing with bolts, I did that in my rear one and worked a treat. It just allows you to manouvre the locker head in easier without grinding a section out.
I have a bare 80 front housing here but not that keen to part with it just yet and im in auckland anyway.
- Sausage Shack
mayday wrote:You can fit a locker head into a non locker housing by removing the studs that hold the head and replacing with bolts, I did that in my rear one and worked a treat. It just allows you to manouvre the locker head in easier without grinding a section out.
Thanks for the info, Are you sure you dont want to part with it? The bare housing is all i need and im not worried about the freight side of things I can sort that?
Will think about it, its actually a complete diff disc to disc but the side gears and the axels are both stripped. I was going to keep it for possible coil conversion on my 70 but would look at exchange on pair of 60 diffs complete?
- Sausage Shack
Bump, Still looking for one
have got a bend front locker housing missing most of the brackets off it. was going to straighten it but havent got around to doing anything with it.
- Sausage Shack
U-BOAT wrote:have got a bend front locker housing missing most of the brackets off it. was going to straighten it but havent got around to doing anything with it.
Pm sent.
- Sausage Shack
Bump still looking, Didnt realise these were so hard to find.
Hey, i know a guy who wrecks 80 series cruisers, thats all he wrecks... but up in west auckland. pm you with details. he might be able to help ya.
- Sausage Shack
micahb wrote:Hey, i know a guy who wrecks 80 series cruisers, thats all he wrecks... but up in west auckland. pm you with details. he might be able to help ya.
Details would be great thanks mate
