Youve done all the usual checks, wheel bearings etc? how did you set the castor?
Yes
Set the castor off the top mating face on the passenger side king pin on the knuckle.
did you throw a skinny little set of wheels on it and take it for a blast to see if that makes any difference
No but it is only on 33/12.5/15's. Its getting 35's in the near future.
QUADRACER
Post subject: Re: Death wobble!!!!!
is the damper too soft,also check if the problem gets better if you let the tyres
down.
Hasn't got a dampner at the moment. As for tyre pressure...... Id say Sam is taking note of this thread.
Hey tom, what steering setup and stuff did you use?
Cheers Daniel
Cheers Daniel
Its all standard Play-doo steering. I put the Prado pitman arm on the Surf box.
So am I correct in thinking that that castor is right???
Thanks for your ideas fellas, can't beat having talented people to bounce ideas off
