As the title says i have got a few Trailgear Front Axle Rebuild Parts as listed below.
Toyota Solid Axle Spindle Brass Bushings $60 for the pair
Toyota Rock Ring Knuckle Felt Protectors $30 for both sides
Rock Ring Extended Stainless Button Head Bolt Kit $20 for both sides
Trail Gear Trail Safe Inner Axle Seals (Sold in Pairs) $25
Trail Safe Toyota Knuckle Ball Polyurethane Wiper Seals and Rock Rings $85 for both sides
Aisin FWH Hub Outer Dial O-Rings $25 for both sides
LONGFIELD TOYOTA KNUCKLE LIFETIME WIPER SEALS Set of 2 $70
Toyota 54mm Wheel Bearing Nut Spindle Socket $25
Hilux Wheel Bearing Inner Grease Seal, also required when doing the IFS Hub Swap.
Plus postage which on most items would only be about $5-$6
PM me if interested
Cheer
Tim
