wanted hilux 4.5 ratio diff
- ca18det_sj413
- Winch master
Hi i am after a 4.5 ratio hilux diff head in the wellington / palmerston north area. Just a open diff suitable for welding. Thanks
- KIWI_TERRANO
Re: wanted hilux 4.5 ratio diff
http://www.trademe.co.nz/motors/car-par ... 908348.htm use the rings off it and sell lsd to make money?
- ca18det_sj413
- Winch master
ive seen that but i suspect its the pinion bearings that are stuffed on it and the pinion bearing kit for a hilux diff is $200+
