urgent help plz all SORTED thanks
- jonossiksilvia
im refitting my rear diff into my surf. prob is the left rear axle wont fit back in properly. theres 5mm between the 4 bolt flanges. axle is in spline as it turns diff. when putting pressure on it it stops the axle from turning. any ideas
Last edited by jonossiksilvia on Sat Nov 19, 2011 11:50 am, edited 1 time in total.
- jonossiksilvia
Re: urgent help plz
is it posible the spline on axles have a different grove in on spot? cheers
- muddyhilux
Re: urgent help plz
no splines will be fine with only 5mm left,try lifting the hub up and wiggling side to side
- jonossiksilvia
Re: urgent help plz
yeah been trying that last half hour. im stumpted as the right one went straight in
Re: urgent help plz
Turn the drive shaft as you push the axle in
- jonossiksilvia
Re: urgent help plz
All sorted guys. After bout doing the 100th time of trying to get it in it finally went in. who knows wat stopped it working first 99 times
Re: urgent help plz all SORTED thanks
Your mouth didn't have quite the right slant and your tounge was sticking out to far
Who knows what it was, we all know that one day it will happen just the same again for no reason
probably when in a hurry, bloody Murphy and his laws
- jonossiksilvia
meatc wrote:Your mouth didn't have quite the right slant and your tounge was sticking out to far![]()
Who knows what it was, we all know that one day it will happen just the same again for no reasonprobably when in a hurry, bloody Murphy and his laws
Lol that sounds a good enough reason why it wouldnt go in mate. I know wat to next time now to stop it happening again.
