Been a member of this forum for 5 minutes and alread hooked on reading what people are writing about
If your in Wellington and have a spair wheel I need you help
I'm in need on a spair tire for my Suzuki .
Preferably a 36x12x15 simex.
But a cheap 35 on a rim will work in the mean time wild I surcharge for the a matching. Simex
It is a hilux bolt pattern.
Thanks for the help
Wanted spair rim and tire 36 or 35. In Wellington
ford ranger wildtract and sj.
Re: Wanted spair rim and tire 36 or 35. In Wellington
007 wrote:Been a member of this forum for 5 minutes and alread hooked on reading what people are writing about
Thanks for the help
a suzuki with 36's
keithal wrote:007 wrote:Been a member of this forum for 5 minutes and alread hooked on reading what people are writing about
Thanks for the help
a suzuki with 36'sgot any pics??
Thats what i was thinking
have a chat to bolo or skid, could also try williamhamilton
Haven't had it long, I brought it of a Dion in Levin who did the build. There are some mean trucks that way.
It is set up to run 40s (I should start saving for some super swampers.)
The holden engine runs sweet.
Jerry wrote:have a chat to bolo or skid, could also try williamhamilton
No luck. 35 and 36 in singles must be hard to come buy
Its got beadlocks on it you only need a spare tube and a punture repair kit for it
dont even need a tube just a valve and glue/patch
- wgtnnewbie
I remember that thing from the first Queens birthday teams challenge, apparently it climbs like a mountain goat but can be kinda interesting on the way down....lol. It is an impressive wee beastie.
Just on idle it wants to go. When you rev it it moves about an inch side ways. As crazy as it sounds it can be driven slow the engin dose not have to work very hard to climb the steepest of hills. son loves it, he gave My jeep jk rubicon a new name the slow one.
My next mode is a 4 point harness.
sig wrote:dont even need a tube just a valve and glue/patch
New to beadlockers
On the trail would yOu recommend to, take spoons and repair from inside of rim. Or take the bead off.
007 Dave
007 wrote:New to beadlockers
007 Dave
Nah leave the spoons at home, jack the truck up on the highlift jack, leave the wheel on and undo all the bolts that fix the bead to the rim (5mm hex drive) and pull the bead of the tyre towards you and stick your hand in and pull the tube out, repair the punture or stick your spare tube in and fix the old one when you get home and stick that away as your spare, reassembly is the reverse and pump the tyre back up
HI All
williamhamilton is sorting me out a new tire and rim
All
All
