Eaton Elocker
Eaton Elocker
My question is the prado 90 rear diff the same as a prado kzj71 8inch 4.88, as I been looking at these Eaton Elocker, I have been quote 2300 nz for one in nz and then looked at the states and can get front and back for less then one here thanks
Re: Eaton Elocker
Just crawled under both trucks
LJ71
KJZ95
LJ71
KJZ95
Re: Eaton Elocker
Thanks mate they look different dont they, 2 Elockers for 1800 NZ seen them in action they work real well very quick to lock
Re: Eaton Elocker
Looks like the later "hilux" option is listed in the catalogue .... Areyou organising a bulk order
http://www.eaton.com/ecm/groups/public/ ... 128302.pdf
Re: Eaton Elocker
The diff heads themselves will be interchangeable between the two. Ratios are likely to be different.
Do the eaton lockers replace the center carrier (use your own crown wheel?) if that is the case you should be sweet.
Re: Eaton Elocker
Thanks guys for the info, I spend six months of the year in south Texas, always bring back stuff last year was fire arms, this year 4wd stuff these eaton elockers 645 us vs 2300 I got quoted here dam we get ass raped here
Re: Eaton Elocker
Jerry wrote:Just crawled under both trucks![]()
LJ71
KJZ95
A guess here ..LJ71 will be 4 spider & KZJ95 2 spider
