WTB Hilux 4 spider non lsd carrier
rob-mu
Post by rob-mu »
Muddy_munke on here needs a 4 spider non lsd carrier as his lockrite wont fit into his lsd centre he has
Needs it ASAP as his truck is moving workshop this week!
Rob
tomsoffroad
Flopsie
Re: WTB Hilux 4 spider non lsd carrier
Post by tomsoffroad »
Make that a 4 spider 4.8:1 front diff. :mrgreen: :mrgreen:
muddy_munke
Post by muddy_munke »
What they said ^^
I have a 4.8 Rear LSD that will need a good home that could be handy for trading purposes....
This is vital to my health.... Cheers
mylux
Shockless
Post by mylux »
Hi,
I got a 4.8 front diff that i would swap :?:
Don't know how many spiders it's got but going by the amount of cobwebs on it i'd say it'll have at least four :roll: :roll:
Cheers Richard.
027 220 3305
Smurf
Post by Smurf »
According to the ID tag in the cruiser I have 4.88 4 pinion diffs, I hope to remove the rear one this weekend coming as it has a leaking pinion seal and a bit of a whine. If it is a 4 pinion we could work out a swap of some sorts?
muddy_munke
Smurf, I would be keen as but i need a front...
niblik
Post by niblik »
isnt it a lux one ya needin and not a cruiser?
Smurf
Post by Smurf »
Cruiser/prado, my bad. Mine has G144 diffs according to ID plate
By front do you mean you after a hi pinion?
As front and rear are interchageable in a lux?
muddy_munke
After a hilux diff. I always thought they were interchangable....? But I have someone building my diffs for me (installing lockers) and he has found I have two rear nuggets...?
muddy_munke
G144's are 4.8 4 spider...
Smurf
Post by Smurf »
muddy_munke wrote:After a hilux diff. I always thought they were interchangable....? But I have someone building my diffs for me (installing lockers) and he has found I have two rear nuggets...?
I'd be asking him how he tells the difference?
If its an open diff then it'll fit as far as I know. I have swapped heaps of diffs in and out of my YN60 surf, and have never had any issues
My understanding is open diffs, 2 and 4 pinion are interchangeable front to rear, LSDs only fit the front if you shave the end off the axles. And hi pinion diffs are front only
rokhound
Post by rokhound »
^^^^What he said. 8" lux diff heads swing both ways.
tomsoffroad
Flopsie
Sorry fellas but your not quite right 8)
Right here we go.....................
Daniel wants to fit a Lokrite in the rear. He has a 4 spider Lokrite. He also has a Arb for the front. At the moment he has 2x rear lsd 4.8 complete diff heads from a Hilux. I know the housing and the carrier are the same but the crown and pinion ARE NOT. :wink: When he gets his hands on a 4 spider front non lsd complete diff I will be able to put the carrier in the rear with the Lokrite and the housing, pinion and ring gear in the front with the Arb. This means that one of his complete rear 4.8 lsd diff heads can stay complete.
Ya with us :mrgreen: :mrgreen:
rokhound
Post by rokhound »
sounds like you have a mixture of 4 spider and v6 4 spider units. C & P should still identical, with the exception of the bearings. Side bearings and pinion bearing are different.
LSD diff heads will not work (as you have found out)
I have 2 4 spider rear lockrited diff heads in my pos, both out of LN100 series turbo diesel surfs.
tomsoffroad
Flopsie
Front crown wheel on left, rear on right.
They have to be different otherwise pinion meshes on wrong side of teeth because rear spins clockwise and front anti clockwise.
suzolla
Post by suzolla »
No, as Rok says for a std diff the front and rear are interchangable, can't buy front and rear C's and P's as they are both the same, it is only the high pinion that is different.
Tim
tomsoffroad
Flopsie
Tim
:oops: :oops: :oops: Now I feel like a dick :oops: :oops: :oops: The crown wheel on the left is a high pinion. I been doing a fair bit of thinking about this and it made sense in my little brain.
Spose I'll put my tail between my legs and hide behind my welding mask :oops:
Still need a 4 spider carrier tho. :D
suzolla
Post by suzolla »
No worries, can't always be brilliant at everything
muddy_munke
Thanks for all the info everyone. Has clarified a few things for me. I was a bit confused for a we bit there!!
But i have managed to track down a 4 spider carrier in palmy.
Now to get it to the better island and get these diffs back where they belong!
Smurf
Post by Smurf »
Are you interesteed in parting with the 4 pinion LSD at all?
muddy_munke
I'll only have the LSD units spare when they're done sorry.
tomsoffroad
Flopsie
You now have one LSD carrier spare :wink: Still waiting for the 4 spider :(
muddy_munke
Awesome thanks Tom, he said it might take a couple of days to get there... Cheers
