Steering wheel vibration KZN130
hawiii
Post by hawiii »
Hello,
Recently I installed a 2" suspension lift in my manual KZN130 surf , and after the lift have noticed that the steering wheel will vibrate from 20 - 30km. It could be a wheel balancing issue but I think its wierd that it is only noticeable after the lift. Do you guys have any other suggestions as to what it could be?
Thanks
vinceparts
Re: Steering wheel vibration KZN130
Post by vinceparts »
did you happen to tak ethe wheels off when doin the lift? wheel nuts tight
hawiii
Post by hawiii »
No I left the wheels on. The only thing that was removed was the shocks and sway bar and I double-checked them
Smurf
Post by Smurf »
Have you had a wheel alignment since doing the suspension lift?
Winding up the torsion bars will have altered the camber on your front wheels.
hawiii
Post by hawiii »
No I havent had a wheel alignment. Ill have to get one done, thanks
